95 7.3 fuel pump adjustment - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-08-2011, 11:31 AM Thread Starter
i gots a 95 7.3 stroker. iv herd bout the fuel pump screw and the tirangular plate and wat not but i actualy cannot find this plate on the pump. is there something i have to remove to git at the plate or wats up?i no its on the passenger side but wat dpo i have to do to git at this plate. is it at the top or bottom of the pump as well???
thks alot
plas is offline
post #2 of 8 (permalink) Old 10-08-2011, 12:47 PM
I'm not sure what screw you are referring to, but there is a plunger type deal that you have to be careful does not fall into the engine when removing the pump. Also, there is some webbing from the turbo pedestal, that people cut into slightly to create more room to remove the pump. I don't think there is a "plate" on the pump itself. good luck.
1995 F350 XLT Powerstroke Turbo Diesel 7.3l 2wd Crew Cab Automatic. Over 300,000 miles and counting. Aftermarket Downpipe, High Pressure Crossover Hose, Viper alarm and remote start, Tranny cooler, Cat delete, Homemade open air intake, Dick Cepek cab lights, Glow Plug Relay Mod, IDM Mod, A/C Mod, Dual Electric Fans, PHP 6-Position Chip.
jtbel is offline
post #3 of 8 (permalink) Old 10-08-2011, 01:28 PM
dieselcamino's Avatar
you cannot turn up the fuel pump on a 7.3 powerstoke for more fuel like an older diesel if that what your looking to do
1996 f-250 PSD xlt single cab longbed
Tymar intake/Tymar Hpx line
custom 4 inch turbo back side pipe
swamps injectors
wildman 6 pos. chip
87' king pin d60
35" bfg mtr km2 on american racing rims
-Bio-diesel ready-
dieselcamino is offline
post #4 of 8 (permalink) Old 10-08-2011, 04:19 PM Thread Starter
Iv read and seen pics of it. And my buddy told me. There's a triangle cover and then. There's a screw
plas is offline
post #5 of 8 (permalink) Old 10-08-2011, 05:11 PM
You have to be talking about the 7.3 IDI, offered from '88 till about '94. They had a real injection pump that probably had a smoke screw you could adjust.
There is an "Injection pressure regulator" on the 7.3 PSD's that's in the fuel filter canister that some people have modified to increase injection fuel pressure, also known as the "BB-mod" that does increase performance. But there's no screw involved that I've ever read about.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #6 of 8 (permalink) Old 10-08-2011, 05:40 PM Thread Starter
O really. We'll I didn't no that. I guess I'm wrong. Sorry everyone. But abouts this regulator. Where would I find out how to mod it?
plas is offline
post #7 of 8 (permalink) Old 10-08-2011, 09:32 PM
bugman's Avatar
My Photos: (12)
Here is a link to Baz's pages where he will discuss and tell you how to do the fpr mod along with other things about your truck. You can also just buy a California regulator spring for your truck and put it in and do really the same thing without messing with different set screws and parts. Sorry I don't have the part number for the California regulator change out, perhaps somebody else on here will have it for you.
bugman is offline
post #8 of 8 (permalink) Old 10-09-2011, 10:16 AM
Patrick Feeley's Avatar
My Photos: (19)
Fuel Pressure Regulator, California Version (contains spring, valve spool & new brass plug)
(Ford) F6TZ-9K061-AA
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
