95 f350 #9 fuse - Diesel Forum - TheDieselStop.com
Old 02-17-2013, 05:11 PM   #1 (permalink)
95 f350 #9 fuse
#9 fuse blows as you turn the ignition on. fuel heater and glow plugs are un plugged. anyone have this issue?
woftracing is offline   Reply With Quote
Old 02-17-2013, 05:50 PM   #2 (permalink)
bugman's Avatar
My Photos: (12)
If it is indeed the #9 fuse that is blowing then there is a problem with the PCM or any of the following PCM Power Relay, Electronic Transmission Control, Injector Pressure Regulator, Injector Driver Module.
The fuel heater is on the #22 fuse.
bugman is online now   Reply With Quote
Old 02-18-2013, 04:40 AM   #3 (permalink)
yes it is the #9 fuse and with more research i am finding that it points towards the ecm like you said. We unplugged the ecm and the fuse still blows instantly. I know thats pretty much a dead short but was just hopeing someone else had this issue and could relate, thanks for your info. Now to find a good schematic and go from there!
Old 02-18-2013, 08:58 AM   #4 (permalink)
bugman's Avatar
My Photos: (12)
You still need to unplug the IPR, IDM, and the connector that goes to the transmission if you have a automatic. And then check if there is still a short.
Old 02-18-2013, 10:19 AM   #5 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
The Electrical and Vacuum Troubleshooting Manual would help you out here! If the fuse was blowing with the PCM disconnected, it is probably not the PCM (more likely a wiring short upstream of the PCM). If you don't mind sacrificing fuses, see if the fuse still blows when the PCM Power Relay is pulled. If it does, you will need to check for a short on circuits 37 (output side of underhood fuse #9 to power input side of the PCM Power Relay and to pin 55 on the PCM. If it doesn't blow, pull the IDM Relay and reinstall the PCM Power Relay. Does it blow then? If it does you will need to check for a short on (as mentioned) the IPR circuit, PCM power (PCM pins 71 and 97), IDM Relay Coil input, and Transmission Control for an automatic. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline   Reply With Quote
Old 02-18-2013, 08:35 PM   #6 (permalink)
This. Instead of unplugging one thing at a time, which could blow a lot of fuses, start by unplugging everyting associated with the fuse, then plugging things back in one at a time, turning the key to RUN and back to OFF each time. One of those times, the fuse should blow. 'Course, if it blows with everything unplugged, then you've got a chafed wire shorting to ground somewhere, most likely.
madpogue is offline   Reply With Quote
