95 F350 keeps blowing #17 Maxi Fuse - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 06-02-2011, 11:43 AM Thread Starter
Angry 95 F350 keeps blowing #17 Maxi Fuse
Batteries were dead, so I jumped the truck with a booster charger(Found out later this is a big NO) At the time I blew #17. Batteries would not hold charge so I replaced them with new ones and every time I turn the key on, it blows the fuse. Whether I turn to glow plug setting or just go straight to cranking over. The truck turns over, but no fire. It is easy to tell when the fuse blows(at $4.00 a pop) as the glow plug light quits lighting up. It blows in less than a second. Where do I start?
DeadBang is offline
post #2 of 11 (permalink) Old 06-02-2011, 12:48 PM
blageurt's Avatar
My Photos: (9)
I would start at the starter relay since the glow plug relay hot wire comes off that .....I would check those and obvious bad grounds first....Wiring Info might be in here....1996 Bronco/F-Series Workshop Manual
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline
post #3 of 11 (permalink) Old 06-02-2011, 01:01 PM Thread Starter
Thanks for the advice. I will begin there. I hate electrical Gremlins!!!
DeadBang is offline
post #4 of 11 (permalink) Old 06-02-2011, 08:05 PM
catskillfire51's Avatar
I don't remember what fuse i kept blowing but it might have been 17 anyways my fuel bowl heater was grounding out so it kept popping that fuse and the truck wouldnt start. if it is that fuse theres two wires as your lookin at the fuel bowl heater on the drivers side down towards the bottom pull the bottom wire put a new fuse back in and there ya go. ya just won't have a fuel bowl heater no more which isn't a huge deal dependin on where ya are
1997
Powerstroke
CrewCab Shortbed
140,000 Miles
5speed 4x4
Mods: 4" turbo back MBRP exhaust with 3" downpipe, Tymar Intake, Edge Insight CS with pyro, LUK Clutch with DMF conversion, Just ordered TW chip
catskillfire51 is offline
post #5 of 11 (permalink) Old 06-02-2011, 11:42 PM
Patrick Feeley's Avatar
My Photos: (19)
I wouldn't think the fuel heater would blow the 50A Maxi (#17), although 30A Maxi #22 for the fuel heater and PCM Power diode does get the power through #17. The 30A should blow first if the fuel heater has shorted. Only thing I can think of would be something in the ignition switch. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #6 of 11 (permalink) Old 06-06-2011, 08:59 AM Thread Starter
Well Guys, the ground at the starter solenoid appear to be good. I have never had a problem with the fuel heater before, but I will try to check it over. My ignition-- How do you check it for problems? Also, could I substitute house breaker for maxi for testing?
DeadBang is offline
post #7 of 11 (permalink) Old 06-06-2011, 11:03 AM
bugman's Avatar
My Photos: (12)
You are going to have to get a ohm meeter and start pulling other fuses. The #17 maxi fuse controls the Generator Charge Indicator, Instrument Cluster. See Fuses 2, 3, 6, 11 and 17 (IP Fuse Panel) and Maxi-Fuse 22. Also See Circuit Breaker 12. You'll be seeing a dead short until you pull one the other fuses and then you can start tracking which circuit that has the problem.
Fuse #2 is for Ambulance (Diesel 215 Amp Generator/Voltage Regulator Only)
Fuse #3 is for Horn Relay, Daytime Running Lamps (DRL), Headlamp Flash-To-Pass
Fuse #6 is for Trailer Right Stop/Turn Lamps
Fuse #11 is Not used
Fuse # 17 in the IP fuse pannel
Fuse #22 is Fuel Line Heater, 215 Amp Generator/Voltage Regulator, PCM Power Relay Coil, Glow Plug Controller
bugman is offline
post #8 of 11 (permalink) Old 06-06-2011, 12:45 PM Thread Starter
So, turn on the key and check the ohm reading across the Maxi 17 and start pulling the other fuses? I hope I got that right.
DeadBang is offline
post #9 of 11 (permalink) Old 06-06-2011, 01:16 PM
bugman's Avatar
My Photos: (12)
No, pull the maxi fuse 17 and then turn the key on. Then you can check which side has power. Then turn the key off. Use the ohm meeter on the other side of the fuse to read the ohms to ground. Then pull each fuse until you get a open reading on the meeter. If you don't have a meeter then unplug all the fuses associated with the maxi #17 then plug in a new maxi fuse. If it doesn't blow plug in the other fuses one at a time until it blows. Just a fyi that isn't really the way to check it but if you have to you have to.
bugman is offline
post #10 of 11 (permalink) Old 06-08-2011, 12:54 PM
Originally Posted by blageurt View Post
Awesome resource for sure! This one is bookmarked for future reference!
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
Rockdog97 is offline
post #11 of 11 (permalink) Old 07-01-2014, 03:54 PM
Having the same problem here. I have disconnected the fuel bowl heater, replace glow plug relay. it started ran for about five mins. I then put in gear and tried to pull out of the driveway and POP blew the maxi fuse again. I have taken all the fuses out under the dash that this also controls and still the same problem. any other suggestions?
1996 f-250 7.3 4x4
bobbaz is offline
