95 powerstroke dies, then fires back up - Diesel Forum - TheDieselStop.com
Old 10-31-2008, 09:30 AM   #1 (permalink)
I have a 95 powerstroke that about a year ago, would miss like crazy. Could pull no codes. Found the valve cover gaskets were faulty. About a month later, truck started dying once in a while while driving. Always started back up. Usd to act up once in a while, now its more frequent. Almost everyday and sometimes several times a day. Still cannot get a code or check engine light. Cannot find an obvious problem with wiring. Any help would be greatly appreciated.
cjohnson3006 is offline
Old 10-31-2008, 11:24 AM   #2 (permalink)
You may want to chage the CPS with one from ford or international
From Patrick F
Camshaft Position Sensor (CPS)
(Ford) F6TZ12K073A, (International) 1821720C99 (below engine 375548)
(Ford) F7TZ12K073A, (International) 1825899C93 (above engine 375548)
(Ford) F7TZ12K073B (Newer, much cheaper CPS!!!!!)
(International for DT466) 1807339C92
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 11-02-2008, 12:01 AM   #3 (permalink)
realbadlarry's Avatar
Check the harness that goes to IPR on the back of the HPOP. Wiggle them with the truck running and see if you can get it to die. Mine had all kinds of crap in the IPR connection, some contact cleaner and some zip ties and all is good now.
95 CCLB 4X4, DP, TYMAR, Adeneline HPOP, 5POS CHIP, 4",3 GUAGE POD, 129k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.Banks IC
realbadlarry is offline
Old 11-02-2008, 05:50 PM   #4 (permalink)
My 95 has been doing the same thing for a while now. Has anyone had success with a new CPS??
Could it have anything to do with Injector Problems?
LCRLUI is offline
Old 11-03-2008, 10:48 PM   #5 (permalink)
see my prior post
