96-97 Water Pump heat return nipple - Diesel Forum - TheDieselStop.com
Old 01-25-2009, 02:38 PM   #1 (permalink)
Hi All,
Just installed new water pump from NAPA only to find out that my old heater return nipple is too small for the new pump. Went all over town looking for the right size and couldn't find it.
Does someone have a Ford pn for it or know if I can pick it up at NAPA monday morning?
Thanks,
Mike
PS: The water pump install was easy! Except for the nipple.
1996 F-250 XLT, 4x4, 5 spd 4.10, 315k, 255x85x16, TS Performance Chip, ISSPRO Pyro & Boost gage, Tymar Intake, LUK clutch & fly, 3" hypermax w/race pipe, 2003 S-code rear springs, gutted EBPV, Dale I HX mod, IDM mod, Amsoil BMK-11 oil bypass, Coolant filter, BB shim, AC mod, Super Duty starter, 4 qts oil in trans. Rebuilt trans @ 160k, 4 ball joints @ 178k, injector O-rings @ 208k and 278K (p.side only)
mikek6 is offline
Old 01-25-2009, 02:57 PM   #2 (permalink)
They may have sold you the wrong pump...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 01-25-2009, 04:29 PM   #3 (permalink)
Same basic thing happened to me, but it was the other way around. Nipple was too big. Come to find out that the WP i pulled was a later model pump and the one Napa sold me was for an actual 1995 model. Fortunetly i found that out before I installed the pump.
Rick
1995 F350 PSD 4x4 C/C LB
Tymar style intake, gutted kitty, more goodies to come!
Transplant is offline
Old 01-25-2009, 10:42 PM   #4 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Early ones are NPT and the later ones are straight-thread o-ringed. Sorry I don't have any part numbers or sizes. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 01-26-2009, 02:05 PM   #5 (permalink)
Jcart's Avatar
The latest versions are a straight thread o-ring version and if I remember correctly they are (at hydrolic shop) a size 10 boss o-ring fitting (brass ones) with a nipple 5/8 I.D. for the heater hose (IIRC). Here in Canada are under $10.00....significanly less expensive then the stealership.....which it seems I was quoted 10 times that much.....
Take the pump to your local hydrolic shop and check to see that it is a size 10 boss fitting and match a nipple size with the stock heater hose I.D.
jrc
97 XLT F250 CC ZF-5 (now ) DIY short shifter 355's D60 air locked T Wildman files, 'jectors, SD Hpop, DIY E-fans, IC, DP 4" exhaust, SS resonator, RSK, SD springs all corners, Velvet rides, Custom Aluminum Drybox/fuel tank, air bags, E-air compressor, VisionX HID/LED's, E fuel, F26D rear tank, E-fan Tranny oil cooler.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 01-27-2009, 10:41 AM   #6 (permalink)
Yes, its a size 10 O ring boss. Got one with adapter to fit the old 1/2 NPT with nipple. Bought at local industrial supply for $8.
Thanks all for the replies,
Mike
mikek6 is offline
