'96 CPS part number - Diesel Forum - TheDieselStop.com
Old 01-27-2009, 08:16 AM   #1 (permalink)
'96 CPS part number
Okay guys,
My CPS is crapping out, so I went to the Ford dealership to pick up a new one. BUT, they said they are on back order and are only shipping "emergency" orders (aka + 20% on the price). The part number they gave me was F4TZ-12K073C. Wouldn't the CPS for the early SD work for us as well? They had plenty of those.
What is the International part number for our trucks? I want to try the local International dealer to see if they have a CPS in stock.
2005 Excursion Limited, 6.0L PSD, 4wd. Mods by Rudy's Diesel Performance: Powermax Turbo, new oil cooler, EGR cooler delete, Head Studs, S&B Intake, SCT tuner w/ custom tunes, Edge Insight CS.
1996 F-250, 7.3L PSD, crewcab, 4wd, 295/75R16 Terra Grapplers
6LMonster is offline
Old 01-27-2009, 08:19 AM   #2 (permalink)
I have a Int number give this a try 1824948C1
1997 F250 XLT CC PSD E4OD 4.10LS (AB CALI Truck)
3" down pipe
18k mod
DIY intake
2" leveling
egt,trans,boost,water,oil,oil temp,volts
Cat delete
1996 F250 XLT EC PSD E4OD 4.10LS (AB CALI TRUCK)135K
DIY intake
DB exhaust brake
HD trans cooler
ono_55 is offline
Old 01-27-2009, 08:21 AM   #3 (permalink)
Her give this number a try 1824948C1.
3" down pipe
18k mod
DIY intake
2" leveling
Cat delete
DIY intake
DB exhaust brake
HD trans cooler
ono_55 is offline
Old 01-27-2009, 09:13 AM   #4 (permalink)
Int will have it and it will be about 100 dollars cheaper. My new "spare" was just under 80 bucks. They have filters and everything for less.
Bob D is offline
Old 01-27-2009, 09:16 AM   #5 (permalink)
Well, the CPS at Ford was $35. For the Super Duty 99-03 version it was $27.
Does anyone know if the Part Number that Ford gave me is correct for our trucks?
Holy cow, just called our local International Dealer with the 1824948C1 part number and was quoted $287/ea!
Old 01-27-2009, 10:36 AM   #6 (permalink)
blageurt's Avatar
Ford 94-96 # F6TZ-12K073-A . . . Ford 97 and up # F7TZ-12KO73-A
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 01-27-2009, 10:43 AM   #7 (permalink)
Okay, so what is up with the # the Ford guy gave me?!?! F4TZ-12K073-C.
Old 01-27-2009, 10:54 AM   #8 (permalink)
Autozone and NAPA both carry them IIRC they are about $25 at the zone.
97 F250 Ext Cab E4OD,224K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
Old 01-27-2009, 12:01 PM   #9 (permalink)
Okay, spoke with the Ford guy again...
The CPS for 94-96:
Old Part # F6TZ-12K073-A
New Part # F4TZ-12K073-C
I just bought them through www.fordparts-fordparts-fordparts.com , which is Y2K Ford in Seattle, Washington
They have them for $18.14 each!
Old 01-27-2009, 12:14 PM   #10 (permalink)
They have either gotten really cheap or Im thinking the wrong part.
Bob D is offline
Old 01-27-2009, 12:16 PM   #11 (permalink)
Nope, it is the correct part. MSRP for the CPS is $35, they just sell them cheaper.
Old 01-27-2009, 12:23 PM   #12 (permalink)
they had a recall on them awhile back maybe that is the reason they are so cheap.
Ford F250 Short Bed Extended Cab/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
