96 E4od - Diesel Forum - TheDieselStop.com
Old 11-17-2009, 07:27 PM   #1 (permalink)
96 E4od
Can anyone tell me exactly which components tell the E4OD when to shift on a 96 F250? I know about the Speed Sensor in the rear axle and the Accelerator Pedal Sensor on the accelerator pedal...both have been replaced. However, there is something else that is causing this transmission to shift erratically.
ggj13557 is offline
Old 11-17-2009, 08:24 PM   #2 (permalink)
midwestconnection's Avatar
I had to change the plugin to the differential sensor as well as the sensor itself.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
Old 11-17-2009, 10:47 PM   #3 (permalink)
DaveBey's Avatar
My Photos: (203)
ggj13557 -- This should help!
Transmission Electronic Control System
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4 BTS-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●6.0L Fan●APCM 245,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 11-18-2009, 10:29 PM   #4 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I can tell you for a fact that the ICP sensor will make the tranny shift all kinds of retarded. i had a bad ICP last week and it threw the engine light on and I thought the shifting was gonna break my neck.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-19-2009, 05:12 PM   #5 (permalink)
What exactly is the IPC sensor? It doesn't show up as having any input into the transmission according to The Transmission Electronic Control System posted by DaveBey. Where is the IPC sensor located? Thanks.
ggj13557 is offline
Old 11-20-2009, 03:01 AM   #6 (permalink)
It is called the ICP sensor (Injection Control Pressure). It is located on the driver side head under the engine cover at the front of the motor. If you open the lid on the cover and look inside, look to the right of the fuel bowl/regulator and it is right there sticking up. whether or not it shows it in the manual doesn't mean a thing. Guys have had weird shifting issues when the third brake light bulb has burnt out. I can;t even begin to explain the correlation between the cause of some of the issues but I have learned the answers to them. I can tell you for a fact cause it happened to me that the ICP sensor will cause shifting issues. Also check your third brake light. I know how stupid it sounds but believe me it happens.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-20-2009, 02:24 PM   #7 (permalink)
Window&Door's Avatar
On a simple note, the brake light switch can make it shift weird too. When mine went, the trans always thought the brakes were on so TC would only lock at half-throttle or more and unlock under half throttle... Even in freeway driving. Was super annoying. I think I paid 20 bucks for the switch.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
