96 F250 7.3 Idler Pulley - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-20-2005, 11:08 PM Thread Starter
OK i have a friend that needs me to replace her Idler Pulley....Is there anything i should need to know about replacing it? Any special tools, tricks anything like, or if anyone has a how to on it that would be great too!!!
Thanks for your help Guys
talonwrx2002 is offline
post #2 of 6 (permalink) Old 09-21-2005, 07:17 AM Thread Starter
Re: 96 F250 7.3 Idler Pulley
Anyone?!?!?
post #3 of 6 (permalink) Old 09-21-2005, 09:54 AM
T-50 torx on the idlers. The tensioner pulley is 15mm bolt, reverse thread. Keep in mind that the idler below the alternator is grooved, the upper one is smooth. The tensioner pulley is smooth as well. If the tensioner looks out of alignment and pulled forward it is worn and will need replacing.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
post #4 of 6 (permalink) Old 09-21-2005, 12:56 PM
If the idler pully bearing is going, but you still have all of the parts (hasn't flown off yet) you can get a 6203S sealed ball bearing and replace just the bearing, saves a few $. Do em both at once and check all the others, especially the tensioner pully.
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #5 of 6 (permalink) Old 09-21-2005, 01:06 PM
My Photos: (61)
When I did mine I used a NAPA replacement due to being on the road on a Sunday afternoon. The lever is slightly longer and the tensioner assembly is a bit longer but it fits. The head of the mounting bolt for the tensioner assembly had to be ground down a bit to clear the belt but once there was 1/16" in there it has been fine for a couple years and somewhere around 40,000 miles.
The longer lever works fine on the factory belt.
I found it easier to get the mounting bolt out of the aluminum bracket it goes into (steel bolt into aluminum and all, you know) by removing the alternator and belt, removing the bracket and use a 1/2" drive impact. Loosen a hit, tighten a hit, loosen a hit etc. until it comes out. It makes the threads in the aluminum bracket stay there.
Don't forget, NeverSeize is your friend on reassembly.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #6 of 6 (permalink) Old 09-21-2005, 01:13 PM
Yea, I just checked this out the other day, both Gates and Goodyear both sell a tensioner with a longer lever. I had both in my hand and they are exactly the same just in different boxes. I didn't have any problems with fit up though. I'm a prevention type of guy and I did both idler bearings and the tensioner, now I gotta go back and do the water pump (too much play for comfort) and the A/C bearing (just because it's the only bering not new)
