Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 03-02-2005, 02:52 AM   #1 (permalink)
96 F350 PSD Fuel Mileage ????
Hello! I'm new to this site, I have owned this truck for about a year now and it has been the best truck ever. I picked it up in Seattle last year. My question is the truck has about 150,000 miles on it now and just in the pasted few months it seems to not have as much power that it ad when I first picked it up. It seems to run good and all but just doesn’t feel like it used to. Also the fuel mileage seems to have dropped down to about 10.9 mile / gal. Seems low to me. I think before I was getting about 14.5 miles / gal. Does this drop in gas mileage seem normal just for winter time or do you think something else is going on? Any suggestions or help THANKS!!!!
busakiller2001 is offline
Old 03-02-2005, 05:55 AM   #2 (permalink)
Re: 96 F350 PSD Fuel Mileage ????
Try cleaning the fuel screen (I cannot remember the proper name). It's a screen in teh 3'oclock position that can easily be accessed with the fuel filter removed. Debris builds up there. The only time I have ever gotten less than 17 was while towing. I can get up to 21.5 if keeping it under 60 on the highway. It seems like teh truck mpg varies between trucks. I'm sure others will chime in.
'96 F350 SRW 4door 127k miles, 10k, fuel pressure shim, oilguard bypass filter, Amsoil, DP, Royal purple in the rear, stancor relay, SCMT 1705, ISSPRO pyrometer, free flowing 4" intake and Donaldson filter, Dieselsite aux tranny filter, Tymar coolant bypass filter.
mrvmax1 is offline
Old 03-02-2005, 05:57 AM   #3 (permalink)
Dido what he said and
The dual wheels cost you 2MPG easy over a SRW truck, same with the 4.10 rear. I picked up some MPG when I put a 3.55 in my F350.
'97 F350 XLT ext cab
Tymar air intake, Edelbrock shocks.
SomeCarGuy is offline
Old 03-02-2005, 07:56 AM   #4 (permalink)
My Photos: (11)
Yep, first move is to check the screen. I think the technical name for it is the FPR Screen. (FPR = Fuel Pressure Regulator) The fuel regulator is mounted to the right side of the fuel filter canister as Mrvmax said. It is accessible from inside the canister w/ the filter removed, and it is also accessible if you remove the regulator and pull it back a little. Be carefull not to drop anything into the Valley of death or you will be going on a fishing trip. Fun stuff. Anyway. I thing the FPR is held on by 2 10MM bolts.
By-the-way. Welcome to the forum!! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Mileage around here varies by driving habits, gear ratios, 2wd vs. 4wd & area of the country you are in. I've gotten as good as 23mpg empty and as low as 14mpg towing 6-8K.
Good luck
Post again if you have anymore Q's. And again, Welome aboard. [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
His: '95 F350 CrewCab, 3.55 SRW, 5spd std w/ Royal Purple, LUK SMFW, VDO Pillar gauges, Homemade open air intake, 3" Downpipe W/ 4" cat-back exhaust from Tymar, Tunes by DP Tuner, Baby Seat Mod on rear bench, 198K miles. It gets 21-23 mpg consistently (on the highway) and 17 mpg in town. My remaining planned mod list includes Amsoil & electric radiator fans.
Hers: 2004 Chevy Malibu Classic; 2.2Ecotec 4 cylinder. VERY dissapointed in mpg's.
Company Car (Daily Drive): 2007 Chevy Impala, Jet Black
cmichalik is offline
Old 03-02-2005, 08:14 AM   #5 (permalink)
Paul H's Avatar
My Photos: (10)
Winter blend of fuel will drop your mpg also.
In summer just daily driving I get 17.5 to 18.2 mpg.
Paul H
OWNER
2004 Ford F350 6.0L Dualie
1996 Ford F350 7.3L Dualie
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
double U double U double U Dot FOKISD Dot ORG
My Pictures
Paul H is offline
Old 03-02-2005, 11:05 AM   #6 (permalink)
Thank you all for you're suggestions, I'm going to try and clean the filter screen you said this weekend and I’ll let you all know if it makes any difference or not. Also I was wondering if anyone has herd anything about the exhaust system causing poor fuel mileage? I herd someone say something about the down tube clogging up or something? I’m not sure. Maybe you guys have herd of this? THANKS!!!
Old 03-02-2005, 11:12 AM   #7 (permalink)
Sure, switch out the downpipe and kill the kitty and it can't do much but up the mileage. Help get air into the engine and exhaust out of the engine and that will help things out alot.
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Strokerin is offline
Old 03-02-2005, 01:21 PM   #8 (permalink)
My Photos: (11)
Busakiller2000,
Go to the photo section of TDS and search for "TYMAR" or "open air filter. You should gain a few MPG's by opening up the air intake and the exhaust. I'm eventually going to a 4" staight pipe (no muffler) when I eventually get a chip (read: when the wife let's me [img]/ubbthreads/images/graemlins/wink.gif[/img])
So to answer your Q. Yes, a bigger exhaust will help mileage. Start w/ a 3" down pipe. Our stock DP is terible IMO.
