If it wasn't for you guys I cant imagine how much it would have cost me to fix all the things i've done to this truck in the past few weeks....I really appreciate the time you put into this
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID" Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
You could cut that wire a ways back so you could re-splice it and see if you are still getting the short. If you don't get it you need to replace the plug.
2000 7.3 Power stroke turbo,165k miles. Bull dog tuner. Air raid cold air intake.
No, B is reading 5.10 - that is where it should be, A and C are 0.04 - but im seeing less than 1000ohms in B and C which indicates a short to ground if im reading that correctly
Connector looks great, wires are in the loom and it doesn't show any signs of wear or heat issues. Found the 3 wires from the ICP connector down at the bottom of the bunch in the loom and everything there looks A+ - My only other route is to pull the loom off the bunch or ohm test the wire before it goes into the connector down to the bottom
