97 7.3l Turbo Cel Delayed?? - Diesel Forum - TheDieselStop.com
Old 01-27-2009, 01:11 PM   #1 (permalink)
Every start of my 97 leads to a cel after 10-15 seconds causing a rough idle then after the light come on it smooths out??
start- ok
10-15sec- rough idle followed by CEL
result- returns to smooth idle
This happens everytime and I tried to have the code checked but it isnt storing in memory and passes everytime.
Also when i first start driving(cold) turbo spins great and boost is performing as expected but when it warms up completely (10min) it acts like turbo isnt even there during 1-3gears it kinda boggs when i press pedal but no smoke is present. 4-5 gears boost performs well. I just bought a new idm and it fixed my nostart problem but the other symptoms have always (turbo lag and CEL) are still there. Any help would be greatly appreciated.
1997 f350 7.3l turbo
113k miles
4x4 5speed
jgetz22 is offline
Old 01-27-2009, 11:00 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Do you have any hot no-start problems? If so you may want to try replacing IPR o-rings. Also check your fuel pressure. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
