97 E4OD rebuild questions - Diesel Forum - TheDieselStop.com
Old 07-21-2005, 09:39 PM   #1 (permalink)
I am rebuilding the E4OD on my 97 F350 2WD and have it all apart and ready to go back together. I upgraded the clutches with Alto parts, replaced the planets and all bearings, thrust washers and seals and am installing a Tugger kit along with Sonnax upgrade valves on a new pump and have also put in a new solenoid valve.....
the only two things I was wondering about is on the new rebuild thrust washer kit, the old plastic one is replaced by a metal washer on the reverse planet and it does not lay flat and has a slight bow to it; is this normal. The other question is while disassembling the transmission a couple of the thrust needle bearing assemblies droped out of place as I was removing parts but the books aren't very clear on which way they face, some are self explanatory but others seem like they could fit either direction.......Any comments or suggestions?
srt0353 is offline
Old 07-22-2005, 08:29 AM   #2 (permalink)
My Photos: (5)
Re: 97 E4OD rebuild questions
not much time for a detailed post at the moment, look at my sig truck/cars stuff, then e4od build, should have dome insight for ya there.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
