97 f-350 with right bank of cylinders down - Diesel Forum - TheDieselStop.com
Old 10-27-2012, 07:46 AM   #1 (permalink)
Hey guys,
This is where I am so far.Driving two days ago at 55mph with no load, she just started slowly dieing. I was able to limp it home but barely. Long story short, I replaced the left side valve cover gasket, but the only thing burnt on that was for the glow plugs. The truck will start and run on four cylinders. If I unplug the left side valve cover plugs, it shuts off. If I unplug the right side, nothing changes (keeps running). The pins in the vcg spec out at 3.6 ohms. Could the IDM crap the bed on just one bank of the injectors. I replaced the IDm two years ago. I wish I had a spare to throw on to see if that fixes my problem. Thoughts?
otpracer is offline   Reply With Quote
Old 10-27-2012, 08:22 AM   #2 (permalink)
ArmyGuy45's Avatar
Seems like your points on not delivering the sparks to your spark plugs.
Could it be a cam on that side or something?
2000 F350 4Dr 4x4 7.3L Powerstroke
US Army 2005-Present
ArmyGuy45 is offline   Reply With Quote
Old 10-27-2012, 08:26 AM   #3 (permalink)
chuckster57's Avatar
Diesel engines don't have points or spark plugs. And the 7.3 only has one cam shaft.
Look real close at the wiring harness for any signs of chaffing.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 10-27-2012, 08:35 AM   #4 (permalink)
ArmyGuy45's Avatar
Headlight fluid?
A V8 doesnt have DOHC?
Old 10-27-2012, 09:18 AM   #5 (permalink)
The ford V8 4.6 and 5.4 have two camshafts and the V10 does too. The 302, 351, and 460 V8's have one camshaft.
Old 10-28-2012, 06:53 PM   #6 (permalink)
Any real advice on my problem?
Old 10-28-2012, 07:08 PM   #7 (permalink)
In my original response, I said to check the wiring harness for any signs of chaffing. I would pull that side valve cover and verify continuity from the harness connector to the injector plug.
Checking for voltage at the V/C is not advised as it is high voltage. I think maybe a buzz test might help.
Using my iPhone4S right now
Old 10-28-2012, 09:29 PM   #8 (permalink)
Most V engines don't have overhead cams period.
madpogue is offline   Reply With Quote
Old 10-28-2012, 09:36 PM   #9 (permalink)
Very true. Want real fun? Do a timing belt change on a 4 cam import. Makes the dual timing chain on the 4.6/5.4 a walk in the park!
Old 10-28-2012, 09:38 PM   #10 (permalink)
ArmyGuy45's Avatar
So there is only one cam to control 8 cylinders?
Old 10-28-2012, 09:46 PM   #11 (permalink)
Yes. In most traditional V8's there is a crankshaft and a cam shaft just above it. Gas engines use chains most often and Diesel engines use gears. There are 16 lobes ( high spots) and as the cam rotates with the crank, the lobe lifts the lifter which pushes a pushrod. The push rod makes the inner end of the rocker arm raise up and the outer end go down, pushing on the top of a valve and making it open.
Where the lobes are in relation to the "starting point" and their height determines valve timing. Always expressed as a number of degrees in relation to the # 1 piston TDC.
Are you confused yet? Cause then we can get into custom cams and setting the cam timing with different gears and a degree wheel.
Old 10-28-2012, 10:36 PM   #12 (permalink)
ArmyGuy45's Avatar
I always though each bank had its own crank and cam shaft. Crank to control the piston and cam to control the valves in the head. With it being a "V" formation I could see having one crank but would need two cams, one for each bank. I will google the break down of the engine and look for a pic because I am confused on this. I always thought DOHC was two cams on one bank of pistons.
Old 10-28-2012, 10:45 PM   #13 (permalink)
DOHC stands for dual (two) OVER HEAD ( above the cylinder head) CAM.
Any engine with push rods can't be overhead cam. DOHC engines have one cam for each bank. Quad cams have two cams for each bank, like some imports.
Old 10-28-2012, 11:29 PM   #14 (permalink)
Actually, the correct terms are SOHC or DOHC referring to each cylinder head. So a V engine SOHC will have 2 camshafts and a DOHC V engine will have 4. But of course a pushrod engine will only have 1.
Evel486 is offline   Reply With Quote
Old 10-28-2012, 11:31 PM   #15 (permalink)
Shows how tired I am tonight.
