97 F250 HD 4x4 not engaging...Automatic Locking Hubs bad??? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 01-23-2007, 10:50 AM Thread Starter
I have a 1997 F250 Powerstroke with automatic locking hubs. I recently found out that the front hubs are not locking(Got Stuck). The front drive shaft is turning so I know the transfer case is working. I pulled the auto hubs and inspected them. They look OK. Cleaned them and put it all back together and still no 4WD! I have the Dana 50 front end. No vaccum or electronics just mechanical auto locks. Any Suggestions?? Thanks!
Goose1 is offline
post #2 of 8 (permalink) Old 01-23-2007, 10:59 AM
BEECHBM69's Avatar
Re: 97 F250 HD 4x4 not engaging...Automatic Locking Hubs bad???
Go buy some manual hubs and install them. I have Warn's, but others say Mile Marker and Superwinch are ok too.
Dan
97 F250, SC, LB, 4x4, 7.3 PSD,E4OD, 4.10,
Warn Manuals, Tru-cool 4590. Tymar Intake.
. 285/75/16 Pro Comp A/T's,
. DPP downpipe. A work in progress.
BEECHBM69 is offline
post #3 of 8 (permalink) Old 01-23-2007, 10:59 AM
Do yourself a huge favor and go buy some WARN hubs, you should never have problems again. Also if the front driveshaft and your axles are spinning then yes it is the hubs.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
post #4 of 8 (permalink) Old 01-23-2007, 12:00 PM Thread Starter
Forgot to add that when I have it shifted into 4WD and in gear I can turn the front axles by hand. They turn oppisite directions.
Goose1 is offline
post #5 of 8 (permalink) Old 01-23-2007, 12:32 PM
Nit
thats fine, but teh hubs are screwed, manuals are far better, teh suto is supposed to engage at 3/4 of a forward turn of teh driveshaft, then to release disengage 4wd and reverse for 10 feet. mostly if autos are left on they burn up teh grease adn the brass locckign ring wears down to the point that it will not engage, then you get stuck.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
post #6 of 8 (permalink) Old 01-23-2007, 12:40 PM
Neighbor of Mine many years ago (1985?) spent $350 fixing ONE automatic hub on His little K1500 Chevy when He could have bought the replacement kit to replace BOTH hubs for $99. Nice looking truck but I NEVER understood the Owner! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #7 of 8 (permalink) Old 01-29-2007, 09:40 AM Thread Starter
Re: 97 F250 HD 4x4 not engaging...Automatic Locking Hubs bad??? Solution
Guys,
Thanks for the help!!! I took the advice and installed Warn manual locking hubs(#11690) and spindle conversion kit(#32721). The only special tool required was the spanner socket which I got at Orielly's($16.00) This is an easy task!!! 30 minutes total!! Warn has great instructions and drawings. If you ever need help call Warn or look on their web page.
Total price for hubs and conversion kit was $300. I also replaced brake pads and wheel bearings and races! $160...Not bad considering 107k miles!!!!!!!!!!1
Thanks again!!!
Goose1 is offline
post #8 of 8 (permalink) Old 02-16-2011, 09:25 AM
engages in reverse
Hello-
reviving an old thread here, but I am having an issue and haven't seen it on here yet.
My 4 wheel has been working well all winter, and then suddenly I noticed it not engaging. However, if I put my truck in reverse and just back up a little bit, it engages and then all is good. Any thoughts?
I have a 97 f350 on 35's with autohubs.
Thanks-
Adam
adamwartman is offline
