Hey everyone, just got a 97 F250 4x4 super cab long bed automatic. My first personal diesel- work with them everyday though. I have an odd question- twice now, I've been creeping along, and I depress the brakes, my truck shuts off. No sputter, just straight cuts off. lights are still on. It hasnt happened while driving, just going real slow in the parking lot, and just when I get going when the light turned green... Any thoughts? The trans shifts fine, it doesnt run rough... I do have to clean the air filter... and it doesn't smoke when driving or overly smoke when cold starting. I appreciate any help guys!
I'm no expert , but own a similar truck. It is known that the third brake light on the back of the cab can cause problems it is integrated into the running circuits some how and since you mention hitting the brakes, I would start there.
When I purchased my 97 several years ago I removed and cleaned all bulbs and sockets, I also removed disassembled and cleaned the turn signal switch, it had a ton of corrosion in it.
I love my 97 and hope yours serves you as well as mine serves me.
ETA: there is a recall on the brake switch mounted on the master cylinder, your truck may or may not have the upgraded part, it catches fire. Go to your Local Ford dealer they can check your vin# and update if needed.
97 F250 HD, 4x4, Ext Cab, Long Bed, 150,000 miles, 4.10 gears, Banks big hoss chip, intercooler, exhaust brake, down pipe, tymar, rebuilt trans, purple t/c, firestone air bags /w compressor, boost and pyro gauges.
I doubt that the third brake light is causing this problem, it causes a lot of problems with the cruse and torque converter but not driving and killing the engine.
The first thing that I would change out is the CPS. Killing the engine at slow speeds is usually one of the first symptoms that come up when it starts to go bad.
Jim Sult / Excavator (we dig it) Trying to fix it? KISS IT"KEEP IT SIMPLE STUPID" Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, BTS Trans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
sweet deal- I've read getting them from Autozone or Advanced auto is bad- they don't last as long... word on this? if true, where to go to get the correct one? part numbers?? will be doing a search as well...
'95 F350 psd/automatic. Fueled exclusively by DRM's W85.
Junior's truck - 1970 AM General deuce and a half. The original oil burner.
Thanks for all the help guys!! getting the CPS replaced on Friday. I have to install a new power steering pump and belt, so let my mech take care of the CPS too. I don't have enough time to do it. Funny thing though- I changed the oil and filter, and the fuel filter... and it hasn't done it since. Still replacing it. A buddy of mine has a scanner that reads Ford codes- P0344, P0478 and P0470. So I need to replace it anyway. Now I just have to work on the other two. Meh. I'll do it when I get down to Lejeune.
1997 F250 7.3L super cab long bed 4x4 with 160,997 miles. LOVE IT!!!
Might as well replace the power steering lines too, one of them acts as a cooler on mine, it does a big loopdy doop in front of the engine and returns to the pump (i think) It was cheap too and they had it in stock at advance auto which i could not believe, only about twenty five bucks. I put about five coats of paint on it first before installing
