97 F250 Running Rough - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 05-08-2009, 01:28 PM Thread Starter
I have a 97' F250 7.3L Powerstroke Turbo Diesel with 321k Miles on it. At times the truck will seem to run fine with the exception of it sounding like its missing on 1 piston. It has been like that for a while. Recently, the truck started running rougher with the transmission shifting prematurely and acting like it has lost power. Now this is not constant it will shift back to running fine but when it has it problem, it is really random when it happens. Now a little after the transmission starts shifting prematurely, the check engine light will come on and sometimes stay on or maybe just go on and off a couple of times. When the check engine light comes on, the transmission shifts really hard and acts like its fixing to rip out the transmission. Basically it seems like it loses power. I'm guessing it is the injectors but I don't want to spend the $300 a piece unless I'm sure thats what it is.
97' F250 XLT Extended Cab 4x4 7.3L Powerstroke Turbo Diesel, 321,000 Miles
cbassett1 is offline
post #2 of 11 (permalink) Old 05-08-2009, 02:15 PM
FordFisherman's Avatar
My Photos: (5)
Did you pull any codes? Sounds like the PCM is on its way out? Not sure though. Have someone check for codes to start. I don't think bad injectors would make the tranny shift like that.
96 F350XLT 4x4 Auto 7.3 Straight 3.5 exhaust 3:55
DIY Intake, 3" downpipe, SCT tuner, Pyro Boost Trans Gauges-Front add-a leafs, Dieselsite Coolant Filter-265,000mi.
FordFisherman is offline
post #3 of 11 (permalink) Old 05-08-2009, 05:58 PM
Get the code read .....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #4 of 11 (permalink) Old 05-08-2009, 06:03 PM Thread Starter
I think it is fuel related. Only when the Check Engine light is on does the transmission shift hard and the overdrive off light blinks. It really seems like it doesn't have any power. Like I said it is extremely random when it happens and how long it lasts. As far as codes go, I don't have a code reader nor do I know someone who has a reader and I do not have the money to get a code reader.
post #5 of 11 (permalink) Old 05-08-2009, 06:21 PM
The code will save a great deal of guessing ,,,take it to ford ,,get the code ...
Rick.....
post #6 of 11 (permalink) Old 05-12-2009, 10:33 PM Thread Starter
Ford charges you don't they? I need to spend absolutely as little as possible. Anything that I can DIY I will.
post #7 of 11 (permalink) Old 05-14-2009, 08:41 AM
So you would rather just throw parts at it and see if one gets it right? Are you getting free parts or something?
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
post #8 of 11 (permalink) Old 05-15-2009, 12:32 AM Thread Starter
No its just that it isn't exactly easy to pull the codes. Reason being is because I never know when the light is gonna come on and how long its gonna stay on. With my luck, it would come on right next to a Ford dealership and the second I pull it up to service, the light would go off.
post #9 of 11 (permalink) Old 05-15-2009, 02:45 AM
STurbo90's Avatar
My Photos: (9)
if the lights coming on it most likely stored a code already.
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #10 of 11 (permalink) Old 05-15-2009, 09:24 AM
You can buy a code reader for yourself.
The problem is that anything that you are told without getting a code is just a guess. Your money is best spent getting a code and then getting advice. I agree that it is probably a stored code.
1996 Town Car
post #11 of 11 (permalink) Old 05-15-2009, 07:41 PM
crashmk92's Avatar
Kinda harsh response, considering the question was more along the lines of is there any way to avoid getting price-raped by ford, and trying to save a dollar or two, and in NO way implying throwing parts at the truck.
cbassett1,
The reason it's not a bad idea to go to Ford when the code pops up, is, we're not 100% OBD-2 compliant on our trucks.. We have the connector, BUT, to get the real readings you need a code reader that is up to par with that ROTUNDA version that the stealerships use, that has multiple software packages designed for specific vehicles. For what its worth on our trucks, it CAN be cheaper to get it read at ford, depending one 1 specific thing...
Auto Enginuity has a USB powered OBD2 package that hooks up to your computer for about $250, and then for another hundred bucks or so, you can get the additional software for the PSD that will let you do all of the cool things the stealership can do, like the injector BUZZ test and so on....
If you intend on having this truck for the LONG HAUL, an Auto Enginuity unit wouldnt be a bad spend, BUT, if you don't intend on wrenching on this pickup much, or will be trading up anytime soon, the A.E. package may not be for you, and you could save money going to ford.
Long story boring, the standard $40 obd2 reader isnt going to get you very far on our trucks, so it's up to you to weigh what is going to be better for you...
And by the way, don't let any of the sarcastic replies on this forum keep you from posting or asking questions. For every 1 guy who thinks it's cool to try and make you sound stupid on this forum, there's another 4 guys who will save you an "arm and a leg" in mechanics fees, and tach you A TON about the T444E(7.3l powerstroke) along the way.
Best of luck brother. Let us know how it comes out.
Joe
1997 F250 HD 7.3L PSD E40D 4X4 ; Dana 60 Conversion, 4" Superlift Suspension, ProComp ES9000 Shocks, Skyjacker Steering Stab.,Energy Suspension Poly Shackle & Track Bar Bushings, DIY Baldwin open element intake, 285/75 R16 Yokohama Geolanders,,15w40 Rotella T, Valvoline Maxlife Mercron ATF, Power Services Diesel Kleen (cetane +6), Midland 77-120 CB w/ Firestik FL2 4' Antenna. 1900RPM @ 70MPH. 197000 miles
Truck Birth-Month : October, 1997
crashmk92 is offline
