Ok folks I am stumped.
97 f350 stock crew cab 4x4 299k miles.
Truck will run for 10 minutes and then shut down, runs out of fuel
Here is what I have done. Fuel pump was leaking out of weep hole. Changed fuel pump. Truck still ran out of fuel after about 10 minutes of driving. Pulled tank and pick up foot was in pieces and fuel was really dirty. Tanked drained and cleaned, new pick up screen, blew out fuel lines, new fuel selector valve. New filter.
After all of this is installed, I put about 5 gallons of fuel and fill the filter bowl. Truck is hard to start because of moving the fuel up to the motor and once started only runs 10 minutes before running out of fuel. I fill the fuel bowl up again and the truck runs 9 minutes and then runs out of fuel again leaving the fuel bowl with only about 3/4" of fuel in the bottom.
What should I try next???
Thanks ahead of time.
