Re: 97 powerstroke overheating/ no interior heat...heater hoses not hot but the top radiator hose is
First, is the cooling system full? If it is I would suspect that coolant is not flowing through the system and it could be a sign of a failed water pump.
'96 F-350 Crew Cab Dually XLT, E4OD w/sonnex & tricume springs, 4:10 gears, Western diesel down pipe & HX hose. B&M Hi-Tek trans cooler w/fan. DP Tuners F5. Tymar intake & 4" exhaust.
stuck thermostat?
are both hoses hot?
is the top heater hose firm when the engine is hot (backyard test for thermostat working OK)
definitely check the system level, only other thing I can think of is a plugged up radiator core or some other restriction in the system.
perhaps it's time for good back flush, if that doesn't help the only other thing I can think of is pull the water pump and inspect for damaged impeller?
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
Did it just start this after you changed the t-stat?, or is this the reason you changed it. What thermostat did you use? Im asking because 96-97 use a different "long stem" thermostat and the "short stem" will cause it to overheat the block.
this is why i changed it i got the t-stat from ford
[/ QUOTE ]Do you have the T stat facing the correct way? just a thought.....
Rick.....
97 F 350 ...Lucky 13 "Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
to remove all doubt, you could run without a thermostat just as a test to see if it still gets too hot.
if it still gets too hot, I'd suspect radiator or waterpump, even with a factory clutch fan hardly spinning you should have enough air flow, so I wouldn't suspect a fan issue.
changed water pump still have the same problem. top radiator hose is hard like a brick with engine running heater hoses cool like no water running through them, also no heat this has to be related started at same time. only thing left is the radiator,but this happened all at once not gradually BAM! no heat running hot just like that
after installing the w/p bubbling out of the cap top hose is hard and cool. the short heater hose off the head is hot but after the t connector that branches to the heater core and the lower hoses are cool and the other heater hose is cool also. cant figure out whats going on [img]/ubbthreads/images/graemlins/confused.gif[/img]
[img]/ubbthreads/images/graemlins/shrug.gif[/img] I dont make any sense to me either. The heater hose from the head is hot but the return from the core to the pump is cold? How about disconnecting the supply and return to the heater and flush the core with a garden hose. At least if you get flow there you will be able to eliminate that as the restriction. That might be your reason for no heat but it still wont explain why youre overheating.
only the short part off the hose off the head is hot once in the t to the heater core it is not warm at all almost like there is a block in that t. ever heard off that before?
No.Pull it off the core, the head and the radiator and check it. or just cut it out and replace it with a brass T and 5/8 hose barbs. You can even eliminate the T by removing the fitting on the bottom of the radiator and replace it with a plug and just run the hose from the head to the core.
