97 ps shuts off going down road - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 01-22-2006, 10:58 PM Thread Starter
Newbie here...I have a 97 ps manual tranny. I was going down the road and the engine cut off like someone shut the fuel off to it. The gauges and all kept on registering, the electrical kept working. I changed the fuel filter out recently, could the glow plug solenoid be going out? If not, what could this be, where to start? For my sake, please use poor man terms... I have read some of the other posts and I feel very...behind the 8 ball, if you will...ya know...post or email me...I need to fix it soon as my shoes will wear out quick otherwise...
thefiremanjoe is offline
post #2 of 17 (permalink) Old 01-22-2006, 11:42 PM
Re: 97 ps shuts off going down road
The GPR only comes into effect when starting the truck. When you turn your key on does your Wait To Start light come on? If it does not check your number 22 maxi-fuse under the hood, it could be blown. If WTS light comes on and the truck cranks check your RPM guage when you are cranking. If it does not move it could be your Cam Position Sensor.
ART
2003 Ford Excursion...7.3, 4X4.
agsF2501 is offline
post #3 of 17 (permalink) Old 01-23-2006, 12:10 AM
check all the big fuses under the hood... mine ran fine and the next day it wouldn't start, was like the fuel was cut off or something... found a blown fuse changed it and it fired right up.
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 320k miles
2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
post #4 of 17 (permalink) Old 01-23-2006, 12:32 AM
tallfarmboy's Avatar
My Photos: (11)
Sounds like CPS failure, or as stated, unplug the fuel heater and see if the problem goes away.
Good luck,
TFB
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust
tallfarmboy is offline
post #5 of 17 (permalink) Old 01-23-2006, 09:06 AM
CPS or the fuse 22 gets my vote. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bud
1997(12/97) F250 SC XLT PSD 4x4 150k 4.10LS,5spd, 1998 BMW 323i conv, 1987 Mercedes 300D Turbo 175k, Mods include:Luk SM flywheel kit, Hypermax downpipe, no kitten, gutted ebpv, shimmed regulator, Donaldson open element air filter, add-a-leaf front.
BadTrukRisin is offline
post #6 of 17 (permalink) Old 01-23-2006, 06:56 PM Thread Starter
How do I fix the CPS?
post #7 of 17 (permalink) Old 01-23-2006, 07:14 PM
It is a sensor on the front of the engine held on by a 10MM bolt that is sometimes cranky to remove. It has a connector on it. Look above your crankshaft pulley and you will spot it. Hope this helps. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bud
post #8 of 17 (permalink) Old 01-23-2006, 07:41 PM Thread Starter
Is this something I can do myself and what is a price, good price, to shoot for when buying and also, where could i get a good deal...? Sorry for the run on multiple question...thanks for all the help.
post #9 of 17 (permalink) Old 01-23-2006, 10:09 PM
the part costs right around $150 from Ford. and I changed mine in about 10 mins. pretty easy
jchipper is offline
post #10 of 17 (permalink) Old 01-23-2006, 11:53 PM
Get it at International. 1/2 the price. Same sensor. Hint, always carry a spare. Most here do. [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #11 of 17 (permalink) Old 01-24-2006, 12:07 AM
really the International one is half price? I'm going to have to check that out. Do you happen to know a part number?
jchipper is offline
post #12 of 17 (permalink) Old 01-24-2006, 12:38 AM
KINGTUT's Avatar
My Photos: (19)
It is really very simple. I have searched and searched the archives and the current threads for the post that showed me how to do it, complete with pictures and everything. I hope somebody can find it for you, it makes it a very simple job, maybe ten minutes and I did not even raise the truck.
KINGTUT is offline
post #13 of 17 (permalink) Old 01-24-2006, 11:54 AM
Same here saw a post a while back that had the part numbers from international a good how to description and a picture. You will save a couple hundred dollars doing it yourself and it's fairly easy. I changed mine in both my '97 and '03.
TwistedTiger is offline
post #14 of 17 (permalink) Old 01-24-2006, 03:35 PM
http://www.powerstrokeshop.com/ check there
jchipper is offline
post #15 of 17 (permalink) Old 01-24-2006, 07:06 PM
Mine did the same thing, I put in a new CPS 10k miles ago and no more problems. Look on ebay, I bought a genuine FoMoCo one for $55. They aren't hard to change. It is good to keep an extra one in the glove box. Good Luck
94 psd, F-350, crew-cab, 2wd, dually, 5-speed, South Bend Clutch, 4.10, 3"dp, 4"exh, Tymar intake, Beans Tranny Saver Injectors, SuperChip, 216K miles
91 F-250 4x4,7.3, 5-spd, Banks Turbo, 4.10's, 211k miles
East Central KS
classy_gene is offline
