97 PSD, IH part #,s for lift pump - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 02-23-2006, 02:46 PM Thread Starter
Following is a list of International part #,s for lift pump replacement, go to any Int Truck dealership parts. Cheaper than ford!
The #,s listed show all nesc. gaskets and seals to complete the repair
qty part#
2 685158C1 Rubber sleeves for steel lines @ rr heads
2 1815560C1 seal, o-ring, turbo
2 1815561C1 Seal, o ring, turbo
1 1822749C1 Seal , Ex
2 1816103C1 Seal, washers @ banjo bolt
1 1822120C1 Gasket, ex, turbo base
2 1816103C1 seal, Donuts for ex tubes, into turbo base
1 1824415C93 Pump, incs push rod, and o-ring
Have Fun!
1997, crew cab, chip,remove cat, K&N, 108k mis.
rebuilt trans (e4od), f250 hd, recent ball joints, and front rotors pads, and rr shoes, and am currently chasing fuel leaks!
hibby1329 is offline
post #2 of 3 (permalink) Old 02-23-2006, 06:56 PM
Re: 97 PSD, IH part #,s for lift pump
Hibby1329,
Here are some more IH part #'s if you need them. Al
http://forums.thedieselstop.com/ubbt...=2#Post2492212
'95 F350 Red cc,zf5,157k miles,3"dp with 4" exhaust,Di Pricol egt and boost gauges,DP-Tuner F5,295/75/R16 BFG AT, SD IC, 1.0 A/R,IC pipe kit, and Stage 1's from GTS, South Bend smfw with the con O from BDP.
alpena is offline
post #3 of 3 (permalink) Old 02-23-2006, 09:08 PM Thread Starter
Al, Thank You!, way helpful, hibby1329
