97 psd misses when cold - Diesel Forum - TheDieselStop.com
Old 10-29-2008, 09:23 PM   #1 (permalink)
97 psd misses when cold, but clears after engine gets to normal temp
jarnold97 is offline
Old 10-29-2008, 09:33 PM   #2 (permalink)
My Photos: (6)
Mine does the same crap, i would love to know what it is doing ive checked fuel pressure oil pressure and all possible leaks and loose lines. I might just say the hell with it and order a new fuel pump and iprv, and ips.
Snowheeze is offline
Old 10-30-2008, 06:58 AM   #3 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
how cold is it?? Remember..it IS a diesel. You may have some lowered compression thats not anything to worry about but may cause a cylinder or two to miss until they get some heat in them to fire.
1997 F-350, XLT, dually, crew cab, 4x4, 7.3 PSD, zf-5 speed, Autometer Pyro and boost, DpTuner F5, 3.5"DP , B+W turnover goosneck hitch, 2wd to dana 60 swap
http://community.webshots.com/user/91diesel
18.9MPG
91diesel is offline
Old 10-30-2008, 02:10 PM   #4 (permalink)
My Photos: (6)
Not tryin to hijack the thread but mine does it just at night when im headed home and it is between 40* to 50*. Low compression on a cylinder....dang lets hope not. Wouldnt it burn oil or smoke alittle if it had low compression because of blow by through the rings?
Old 10-30-2008, 02:13 PM   #5 (permalink)
Just done it the last couple of days, temp has been in the mid to upper 50's. It acts like it is a complete shut down, but collects itself before it dies, not just a little miss.
Old 10-30-2008, 11:08 PM   #6 (permalink)
91diesel's Avatar
Check your icp pressure?
18.9MPG
91diesel is offline
Old 10-31-2008, 03:44 PM   #7 (permalink)
if it has a dead miss when the engine is cold then it goes away like someone is flipping a switch then it is a bad injector mine did the same thing
96 cc f-350 4x4 Auto 305k d/p,straightpipe,chip,diy tymar
97 f-350 4x4 reg cab 5 sp, d/p and 4in exhaust, afe, ts 6 pos chip
oregon96psd is offline
Old 11-01-2008, 11:40 PM   #8 (permalink)
My 94 does the same thing. It doesn't matter if you let it warm up for 10 minutes. It will have a miss till it gets warmed up and higher rpm's. Like you said it is just like flipping a switch and it runs great. I was told that it was the the clearances in the injector for the electronics. Well I guess 190K miles, I will just replace all of them. Let us now what you find out.
94 psd, F-350, crew-cab, 2wd, dually, 5-speed, South Bend Clutch, 4.10, 3"dp, 4"exh, Tymar intake, Beans Tranny Saver Injectors, SuperChip, 205K miles
91 F-250 4x4,7.3, 5-spd, Banks Turbo, 4.10's, 309k miles
East Central KS
classy_gene is offline
Old 11-02-2008, 01:27 PM   #9 (permalink)
Excavator's Avatar
My Photos: (11)
Yes the injectors with high miles like over 160 can have worn poppets valves and the armature plate clearance is then out of spec. The spec on new injector armature plate is .004 in and old injector is .002 in. Any thing less will cause this cold miss or no start unless plugged in but after it runs for a few minutes all is good. This armature plate clearance can be measured with feeler gauge but requires pulling valve covers off and then removing the solenoids off injector and is delicate work as you dont want to drop the small screws.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
