97 psd won't rev past 2200 - Diesel Forum - TheDieselStop.com
Old 06-21-2009, 01:06 PM   #1 (permalink)
big hood 379 pete's Avatar
Unhappy 97 psd won't rev past 2200
i own a 97 psd with 237000 miles and the problem i have is when i put the fuel padal to the floor with tranny in park park the motor starts breaking up at around 2200 rmp for couple of seconds as its try to rev up to redline on tac.the truck is bone stock with just a straight pipe anybody out there had this problem before
big hood 379 pete is offline
Old 06-21-2009, 02:44 PM   #2 (permalink)
Window&Door's Avatar
Fuel filter ok? I'd try the easiest first and clean the screen on the FPR and maybe check fuel pressure
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 06-22-2009, 06:19 PM   #3 (permalink)
the truck has a new fuel filter. how much fuel pressure should this truck have. i got this truck last week with the intent to sell and make a few bucks off it i picked it up dirt cheap. what is the easy way to shim the fpr.
Old 06-22-2009, 08:23 PM   #4 (permalink)
I think stock it should have in the neighborhood of 50-60 psi. I shimmed mine with a 3/16 bb from a kid's red-ryder bb gun. A small flathead screw from and electrical receptical works well between the spring too. That should put you in the 70 psi range. That screen, if its plugged, can foul things up and an FPR shim won't do any good.
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Old 06-22-2009, 08:24 PM   #5 (permalink)
Almost forgot, have you scanned it yet?
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
