97 SD 7.3.. push gas pedal and nothing happens - Diesel Forum - TheDieselStop.com
Old 11-20-2012, 10:16 PM   #1 (permalink)
i have a 1997 F250 SD 2 wheel drive, 7.3 turbo, automatic trans..... the problem is sometimes i push the gas pedal it does nothing(just keeps idling) and the "check gauges" light comes on, i can pump the pedal a few time then it goes, BUT the trans will shift very fast through the gears. i can stop and turn the truck off and restart and put it back in gear and it will works fine. this only happens every now and then
chevychevy33 is offline   Reply With Quote
Old 11-21-2012, 09:39 AM   #2 (permalink)
Paul H's Avatar
My Photos: (10)
Bad throttle position sensor on the peddle assymbly. When it fails the truck will try to use Limp Home Mode and trans will shift funny.
The only fix is to purchase a new throttle peddle assymbly from Ford, they never sold just the position sensor seporate.
Paul H
OWNER
2004 Ford F350 6.0L Dualie 246.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 340,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
Paul H is offline   Reply With Quote
Old 11-23-2012, 08:32 PM   #3 (permalink)
massbadass's Avatar
You can get the tps separate, it's a doorman part. it will get worse with time so i'd replace it soon.
Iraq vet and back home for good!
95 F250 SC 7.3PSD 4x4
04 Jeep Grand Cherokee 4.0
ASE Master Tech.
massbadass is offline   Reply With Quote
Old 11-24-2012, 09:52 AM   #4 (permalink)
It could also be the validation switch on the pedal, probably even more likely. Again not sold separately, try spraying with contact cleaner while moving switch. When mine does this I push the pedal all the way to the floor then slide my foot off the side of the pedal so it pops up fast and hard, works every time for me.
1997 F-250 4X4 Powerstroke, ext cab, 3:55 gears, E4OD tranny, DiPricol gauges and 3 pillar pod,Tru-Cool 4739 Max trans cooler, 3" downpipe, dead kitty, Rotella Synthetic,Mobil-1 synthetic ATF,Warn manual lockouts, ..2012 Sabre 34RLQS fifth wheel.
okie1 is offline   Reply With Quote
Old 11-24-2012, 08:41 PM   #5 (permalink)
Had the same problem with my '95 PSD two years ago. It had me perplexed until I found out what it was by reading on here. Sprayed the heck out of it with WD-40 and haven't had a problem with it since.
1995 Ford F-350 crewcab PSD running on B100
frugalyankee is offline   Reply With Quote
Old 11-26-2012, 12:15 AM   #6 (permalink)
The Idle Validation Switch(IVS) is available, but you need to go the electrical component distributor route not the automotive parts route. If you can solder, drill, cut, bend sheet metal with pliers, and measure you can get the proper momentary(IIRC contact when pushed in) type switch from Radio Shack for something like $5 bucks. You just need to make a new bracket to hold it.
Bernhardt
Goliath - 94 F350 444DIT CC SRW 4X4 4.10 Luk SMF Coolant Filter 33X12.5R16.5 Reunel Rear Bumper LineX liner Hunter Green 254K
82 VW Pickup 1.6l TD 5sp Gold Metallic 350K
Bernhardt is offline   Reply With Quote
