ac question - Diesel Forum - TheDieselStop.com
Old 06-03-2009, 04:39 PM   #1 (permalink)
Send a message via AIM to bob807968
ac question
Hello
I need to recharge my system after a total discharge. There is no vacuum present and has a zero charge. do i need to vacuum it out or can i just start adding 134a to it? Anyone know how much goes into these things? Thanks for the help!
Nate
1995 f350 crew long bed, red, 305,256 miles, freshly rebuild with new pistons and rings, 4" ats exhaust with 5" tip, ats wastegate, mag hytec rear diff, edge evolution, edge programmer. bigredf350.net
bob807968 is offline
Old 06-03-2009, 04:46 PM   #2 (permalink)
The lines need to be under a vacuum before adding refrigerant. The refrigerant and any air do not mix well and any moisture makes things worse.
Snowtow is offline
Old 06-03-2009, 08:36 PM   #3 (permalink)
91diesel's Avatar
Send a message via AIM to 91diesel Send a message via MSN to 91diesel
Unless you know what your doing, let a shop do it. You have to pull a vacuum on the system and make sure it doesnt leak. I did it all in my driveway but my dad is in HVAC-R (heating ventilation airconditioning refrigeration) so it wasnt challenging. Theres a bit of equipment needed. A scale, vacuum pump, gauges.
1997 F-350, XLT, dually, crew cab, 4x4, 7.3 PSD, zf-5 speed, Autometer Pyro and boost, DpTuner F5, 3.5"DP , B+W turnover goosneck hitch, 2wd to dana 60 swap
http://community.webshots.com/user/91diesel
18.9MPG
91diesel is offline
Old 06-03-2009, 09:27 PM   #4 (permalink)
chuckster57's Avatar
/\ /\ /\ What he said..If you have the equipment and know how much 134a goes into the system, there are sources for air driven vacum pumps and gauge sets. There is a formula for how much vacum you need to pull based on elevation and for how long for a complete evacuation of the system. If you lost any oil during the discharge, you will need to know how much and replace it. Easier to flush the system, replace the dryer/reciever and add 1/2 of the oil to the reciever and the other 1/2 to the compressor, then pull the vacum.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 06-03-2009, 11:58 PM   #5 (permalink)
Yes you need to vacuum. My 1994 takes 32oz of freon. I used three full cans. That allowed for the fact that the manifold and cans retained a little bit of freon during the charge.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
