Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 01-20-2008, 07:15 PM   #1 (permalink)
Advance Alternators
Has anyone ever used alternators from advance auto? Are they reliable? I got stuck on the road and had no choice but I really want to know if I have a decent alternator or not.
1997 f350, 5 speed, 4x4, 4.10
bigredflatbed is offline
Old 01-20-2008, 07:34 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
In my opinion anything that is rebuilt is a crap shoot. It may last and then it might fail in a couple of days. I once went through 3 rebuilt alternators before I Finlay got one that would work right. I also found that if you have a local automotive electrical shop that will rebuild one for you that it will outlast any of the part store ones. For some reason they take a little more time and check out everything along with having a local reputation to keep up.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 01-20-2008, 07:38 PM   #3 (permalink)
I agree
Normally I do not play the rebuilt game at all but at 8:00 at night in a small town you will take what you can get.
Old 01-20-2008, 07:51 PM   #4 (permalink)
which alternator did hey sell you, was in a Palladiem box or a world wide box. If it was a Palladiem was the box red or gold. I worked parttime there for about years. In general the Palladiems are pretty good, just make sure that your batteries are in good shape and you don't have any grounds in your electrical systm. Make sure you make a xerox copy of your reciept or scan it on the computer if you print it out. As long as you have a copy of the reciept there is o problem returnng a few years down the road if it goes bad and the original thermal paper reciepts fade
2006 F250 CC FX4 5.4L 3.73 gears, 2007 Palomino Bronco B1251 Truck Camper, 2002 Carolina Skiff DLX16 25hp Yamaha 4 stroke,2004 Kawasaki Bayou 250, 2000 Kawasaki Bayou 220
NEG297F is offline
Old 01-20-2008, 07:52 PM   #5 (permalink)
I've never had one last more than about 40k miles, and had several fail immediately or within a week.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 01-20-2008, 08:37 PM   #6 (permalink)
just my .02 but other than NAPA rebuilt I'd shy away from the whole bit. Even NAPA's can wear out prematurely, but at least in my experiences with them I've only paid for one alternator back in 99 and have been getting free replacements ever since no questions asked. On the 94-97's the pulley arm is offset from the factory for some reason, and so I've become accustomed to alternators and the idlers on each side of it going out a lot. I've turned into a mobile parts warehouse for this pickup because of crap like that.
kazavelli is offline
Old 01-20-2008, 10:39 PM   #7 (permalink)
DIESELDUTTON's Avatar
Thumbs up
I put one on about 2 1\2 years ago with no problems at all about 35k miles. Watch, it will probably catch on fire tomorrow and burn my truck to the water line. I have not had any problems with anything from advanced powers steering pump, steering box and alternator. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 01-21-2008, 09:49 AM   #8 (permalink)
I should say that Advance is no better or worse than any of the other ones, with the exception of NAPA.
I've bought a lot of stuf from Car Quest, LOTS from Advance, Auto Zone, O'Reilly's, and NAPA. Now, I almost exclusively purchase from the dealer, or NAPA if there is much of a price difference. I have not yet had to replace a part that I bought from the dealer. I always figure if the first one lasted a quarter million miles, the next one should too and that truck won't be around me when the new part finally fails.
I just don't have time to work on my truck all the time, and my vehicles have been more reliable since I quit using the parts stores junk.
1996 Town Car
Old 01-21-2008, 04:28 PM   #9 (permalink)
Supporting Member
may work for 2 days, or 2 years. seen them both ways
Dads ride 2002 Dodge 24v, dual exhaust, edge comp hot box. tst 40 hp injectors,Piers B-1 turbo dipricol white face a pillar gauges, Suncoast triple disc and valve body occasionally he lets me drive it. 393 rwhp, 807 ftlbs
1996 F-350 CC swr, long bed , 4x4 PSD zf-5, 250k.Swamped, 5" black stacks, dipricol gauges, 30+PSI boost, DP tuner chip, 330rwhp.
95 PSD project
Need IDI parts I got more than most junk yards.
finallygotanIDI is offline
Old 01-21-2008, 08:38 PM   #10 (permalink)
Alternator
I normally only buy from the dealser but when the dealer is closed and the closest Napa is 40 miles away and closed even I will use what I can get.
Similar Threads
Testing Alternators -----Dual Alternators???? 02F350 General Questions 1 09-24-2006 10:55 PM
Need advice (appreciate it in advance) robertw Power Strokes 1994-1997 General 7 06-06-2006 04:56 PM
Which way to advance IP? johnnynegaunee 7.3L IDI Diesels (Not Power Strokes) 2 12-23-2005 09:13 PM
Screwy advance? twelve0six 7.3L IDI Diesels (Not Power Strokes) 1 11-21-2005 11:04 PM
screwy advance... twelve0six 6.9L Diesels 2 11-20-2005 09:01 PM
