Ambulance Package/Alternator - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-17-2005, 06:58 AM Thread Starter
HI,
Does anyone know the differance in the "ambulance package"?
1996 F350..
Specifically, I am looking to swap out the standard 130 amp alternator for the 215 amp "ambulance package" alternator.
I have looked at both, the 215 is bigger obviously, but lines up with holes etc... BUT the 130 amp has 2 plugs that plug into it, the 215 has 1.
Thanks,
Kenny
kmckinno is offline
post #2 of 5 (permalink) Old 12-17-2005, 07:37 AM
BlueMule's Avatar
My Photos: (12)
Re: Ambulance Package/Alternator
read this: [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
<font color="green"> high amp alternator</font>
Rodney#33
BlueMule is offline
post #3 of 5 (permalink) Old 12-17-2005, 03:06 PM Thread Starter
Excellent. Thanks!
I just mounted the new alt and fits great, for the most part. The plastic Powerstroke cover over the fuel filter would need to altered by an inch.
2 more questions:
1. Do you order the wiring "kit" from the dealer?
2. What size serpantine belt do you use...The standard 119 inch looks to be about 1 1/2 -2 inches short? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Thanks!!!!!!
Kenny
kmckinno is offline
post #4 of 5 (permalink) Old 12-17-2005, 03:12 PM Thread Starter
Found the x-tra info... My Bad... Thanks to all for the help!
Kenny
kmckinno is offline
post #5 of 5 (permalink) Old 12-17-2005, 03:29 PM
STurbo90's Avatar
My Photos: (9)
As far as the belts you have to be careful. I had this problem when I did mine.
The stock belt is a 119" "listed" and the ambulance belt is 119.5" listed.
I ordered two Dayco 5081195 which are listed for the ambulance package, at 119.5" and both were too short. When I physically measured them not only were they different lengths, but whey were both too short, one measured 118.75 and the other was 119".
I ended up ordereing the factory belt from Ford and they listed the belt as a 120" belt, but when I got it, I measured it for reference, and it was 119.5".
So I can only gather that the tolerances on the belts are not regulated at all, and the belt needs to be a true 119.5" and all belts are about 1/2" short according to their rating, so I assume the Ford belt is listed as a 120" so you get a 119.5" belt.
For reference, I probably could have put the stock belt back on, but the tensioner would a have been maxed out on travel. I marked the tensioner before the install and after with the correct belt and it was the same, so the stock belt would defitnately be too short.
As far the harness, I had a spool of 1 guage, so I just made my own.
Coincidently, if you do a search, this topic has been discussed a lot recently and you should be able to find all the answers you need.
Here is my 215 amp pics
STurbo90 is offline
