Another rough idle - Diesel Forum - TheDieselStop.com
Old 11-19-2012, 10:35 PM   #1 (permalink)
1997fordman's Avatar
Another rough idle
I have a 94.5 psd with 280k and it runs kinda rough after it warms a bit and the idle settles down. When I first crank it, it runs fairly smooth, but with a slight shake to it and a faint thump in the airbox. As it warms up and the idle lowers, it gradually runs rougher and the thump is more noticeable. It will run like this at all engine speeds under no load. I suspect a hydraulic issue, and I hope its a lifter, but with 280k on the truck I guess it could be injectors. I have had the vc's off and checked all the poppet screws, and armature clearances are right at .002. I also ohm'd out the injector harnesses from the idm and they all checked fine. Tried another idm and no change. The DMF has been replaced with a SMF kit already. I've read that a thump in the airbox indicates a valve train issue such as bent push rod, weak lifter, cracked rocker arm assembly, or bent/burnt/leaking valve, but since it seems to be more pronounced when warm, I believe it to be a lifter. It does have a metallic sound to it as well, though its kinda hard to tell being a diesel. I have not checked lube oil pressure as I don't know where to hook my gauge to or what good pressure should be. I would imagine the pump could be at its end of life.
Sorry about the long post. I just needed a sounding board to see if I'm on the right track or not. Any thoughts?
97 F250HD SC SB PSD ZF 5SPD 4X4 OFF ROAD 230K CHROME GRILLE GUARD GOOSENECK WARN MANUAL HUBS LUK SMFW KIT FIRESTONE AIRSTROKE AIRBAGS OTHERWISE STOCK FOR NOW
SOLD FOR PAYOFF
NEW OLD TRUCK: 94 F250 SC LB POWERSTROKE ZF 5SPD 2WD 279K AND ROLLING LUK STYLE SMF KIT HERCULES REAR BUMPER NOTHING FANCY
1997fordman is online now   Reply With Quote
Old 11-21-2012, 06:18 AM   #2 (permalink)
Anyone?
Sent from my iPhone using AutoGuide.com Free App
SOLD FOR PAYOFF
Old 11-21-2012, 09:12 AM   #3 (permalink)
I would run a cylinder contribution test first. then a compression test. If its mechanical, youll find the problem cylinder.
1995 f350 powerstroke 2wd
1985 f250 6.9l 4wd
1983 E250 6.9l "MPG Max project"
2006 Jeep Liberty CRD
dieseltrucker is offline   Reply With Quote
