Any way to get tach signal? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 05-17-2017, 12:27 AM Thread Starter
I've searched this site and others to no avail. Is there any way to get a standard 12v square tach signal from this thing? I want to use a 3rd party gauge.
Currently to read my tach I have to use the display on the aux RPM controller, but this display is passive LCD and is beyond awful. I'm considering getting a gauge for boost, egt, and tranny temp. It can also show engine speed if I could only get the signal somehow.
1995 E350 PowerStroke ambo
Ball is offline
post #2 of 8 (permalink) Old 05-17-2017, 06:29 PM
There is no "tach signal". The tach is fed by the PCM. The closest you'll get to any "signal" that you could use with an external analog device would be the signal from the CPS, which uses 5V VREF. But it "blips" on every notch on the camshaft, including the ones that actually report the camshaft position. To get the once-per-rev (well, per two revs) "heartbeat", the device would have to filter out the unwanted blips.
That said, any device that communicates digitally via the data port should be able to display the PCM RPM; you just have to decide what device and how you want it displayed.
What's wrong with your stock tach? Or is this a van? Vehicle info in the opening post (NOT your sig) filters for better/quicker answers.
madpogue is offline
post #3 of 8 (permalink) Old 05-17-2017, 11:14 PM Thread Starter
1) Yes, it is a van.
2) The 3rd party device can do neat stuff like record sensors but it's a useless feature without tach. In other words, a built-in tach does nothing for me.
Ball is offline
post #4 of 8 (permalink) Old 05-18-2017, 12:24 AM
Not sure which device you're referring to in (2), but anything you connect to the data port, if it talks to our generation of PCM, it can be configured for RPM. Choices are narrow, however. Forscan or AutoEnginuity on a PC, Torque Pro on an android device, AeroForce Interceptor, a couple Snap-On models....
madpogue is offline
post #5 of 8 (permalink) Old 05-18-2017, 11:11 PM Thread Starter
If you're referring to the OBDII port, no, this device doesn't do that. The OBDII doesn't monitor EGT or Boost anyhow.
It's starting to sound like I'm boned.
Ball is offline
post #6 of 8 (permalink) Old 05-19-2017, 07:01 AM
How can your device read powertrain sensors without connecting to the data port? Actually, the data port does give you boost, if the device attached to it know how to subtract MAP minus BARO. In any event, if you're not using data port currently, you're not boned. Just get something like an Aeroforce Interceptor and dedicate one display to RPM.
madpogue is offline
post #7 of 8 (permalink) Old 05-19-2017, 01:17 PM Thread Starter
to the data port?
I never said I was doing this. I was going to install a half dozen sensors, some of which run parallel to the Ford ones.
Still doesn't have EGT
Well, again, the benefit of this tool is it can record. If I merely needed display, I'd transplant a Ford display.
I think I found a solution, however. It isn't cheap (well, cheaper than then "Aeroforce Interceptor"):
http://www.autometer.com/media/manual/2650-1885.pdf
Ball is offline
post #8 of 8 (permalink) Old 05-19-2017, 03:17 PM
If you want to record, check out TorquePro and CarGaugePro, or one of the Windows solutions.
madpogue is offline
