Anyone have factory Snow Plow Package? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-28-2007, 07:50 PM Thread Starter
Anyone with a F350 have the factory snow plow package? If so could you give me your spring code off the door jamb sticker? I am about to stick my Dana 60 under my truck but I need new leaf springs and I want to get the factory snow plow package for the F350. Thanks fellars!
Dave
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
post #2 of 7 (permalink) Old 03-28-2007, 10:07 PM
Dick Cutting's Avatar
My Photos: (28)
Re: Anyone have factory Snow Plow Package?
The package for them was called the "Suspension package, Heavy Duty Front". Option code #674. It was not called Snow Plow package like it was/is with the SD rigs.
Looking at the window sticker that came with my '97 Reg cab F-350 4x4, it was a $30 option.
They were 5000 lbs rated springs. My door code says "8F" under the SPR column. I also had the camper package on this vehicle. It was payload Pkg #1 (code 201) and is 9000 lbs (GVWR).
TheDieselStop.Com Moderator & Former Photo Editor
Had a May '02 F350 7.3L SC Lariat 4x4 Auto In 5/2016 it had 321.1K+ miles
Had a June '97 F350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD, In 5/2016 it had 208.1K+ miles
Dick Cutting is offline
post #3 of 7 (permalink) Old 03-28-2007, 10:23 PM
do you have a chart of the meaning of different codes?
2002 F-350 4wd psd. hx 48 turbo, single shot injectors, dual stage nitrous, 4 inch duals, 3 pos custom tuned dp chip,ccv mod, aih delete mod,itp regulated return, oil crossover line, sp diesel 10 level kit, afe stage 2 cold air kit, and many other mods and inventions made to engine. monstorbox tranny,triple disc tq, ladder bars, 4 inch susp lift, dick cepek tires on american racing rims and beadlocks, Ford AIC, Auto Enguinity.Billet Badges, custom badges.F-444 Gettin' Stroked
White 2-180 3208 cat
Massey Ferguson 35 3 cyl perkins
Massey Ferguson 6180 6 cyl perkins
Massey Ferguson 255 4 cyl perkins
Massey Ferguson 65 4 cyl perkins
Agco LT-75 4 cyl Cummins
Case 1845C Skid Steer 4 cyl cummins
Case 580 construction King Backhoe 4 cyl case
1986 F-250 6.9 IDI 4x4 265,000 miles *sold*
1994 4wd f-250 ext cab psd
2180 is offline
post #4 of 7 (permalink) Old 03-28-2007, 11:01 PM Thread Starter
Mr. Cutting Thank You Very Much!! I have been all over the place trying to find out the different spring values and no one knows , especially Ford. Is yours a factory 2 leaf or 3 leaf pack? I just don't wanna go through saggy springs like my 250's were. Thanks again
bosefes is offline
post #5 of 7 (permalink) Old 03-29-2007, 08:44 AM
My Photos: (28)
My '97 front springs are factory 2 leaf. I don't have the spring code conversions charts.
According to the sales brochure for '97 250's and 350's, the front spring ratings for a Regular cab 4x4's range from 3,305# to 5,000#.
The source book says that a std Reg cab 250 4x4 has 3305# springs and a Reg Cab 4x4 350 without HD front Sus has 3400# rated springs. Now, this is the range that can exist depending on what engine (gas or PSD) the rig has in it.
The Reg cab 250 4x4 has a 4600# rated front axle while the 350 has a 4800# rated axle. The 350 SC's and CC's had a 5000# rated axle.
Looking again in the source book, the HD Front Suspension package for F-250's (option 674) were 4,600# ratings. It also says that this package was standard with 250's that came with the 7.3L engine. And if I read it correctly, with that package it includes 4.10 gears otherwise without that package you'd have 3.55 gears as the std on a 250 with the PS engine.
The 674 package for the 350's gave you 5000# springs to go along with the 4800# rated axle.
Dick
post #6 of 7 (permalink) Old 03-29-2007, 11:05 AM Thread Starter
So your option code 8F gave you the 5000# rated springs up front?
bosefes is offline
post #7 of 7 (permalink) Old 03-29-2007, 05:27 PM
My Photos: (28)
The 8F is the code on the door sticker.
The HD Front Suspension option code when I ordered was 674.
Dick
