Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 11-02-2008, 07:40 PM   #1 (permalink)
ball joints/tie rods
I am stuck between a rock and a hard spot. I have to replace two upper and two lower ball joints and tie rod ends on the crappy d50. I want to upgrade to a d60 in the future but have not found one and can't get enough down time on the truck to replace it. My question is will any of this be transferable to the d60?
1996 f-250 xl
7.3 diesel
5spd manual
354,000km
4:10 posi
Tw 6pos(stock,emmision,economy,tow,ext,hi-idle)
D.I.Y stg 1 squitters
3"dp-5" Mitre cut stacks
tymar diy intake
autometer boost/pyro
16x10 pro-comp 1069
305/70/16 mt baja atz
1 add-a-leaf in front
3 in rear w/4" blocks
Valair smf kevlar/ceramic clutch kit(noisy)
Makes me money every day
2008 bombardier outlander 800
materi is offline
Old 11-02-2008, 07:44 PM   #2 (permalink)
PSDfreak's Avatar
unfortunately not
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio● ALLFF BRAH!
PSDfreak is offline
Old 11-02-2008, 10:24 PM   #3 (permalink)
u2slow's Avatar
My Photos: (19)
It took me about 4 hours to do the swap.
Floor jack, jack stands, lots of wooden blocking, and air tools.
I did have a complete D60 with steering links and leaf springs. U-bolts I had bought ahead of time.
Its a plug & play affair. Minimal downtime.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw, 9.00R16 Michelin XS
u2slow is offline
