Batt. light - Diesel Forum - TheDieselStop.com
Old 11-11-2012, 05:18 PM   #1 (permalink)
jimzpsd's Avatar
Batt. light
When my truck is at idle, the battery icon on the dash glows and sometimes stays on solid, but whe
n I rev the engine, it goes out.....while this is happening, the volt gauge in the dash and the digital voltmeter (in the APCM) read normal (14.3). Any ideas?
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's
jimzpsd is offline   Reply With Quote
Old 11-11-2012, 07:26 PM   #2 (permalink)
bugman's Avatar
My Photos: (12)
I would pull the alternator off and have it checked by a shop. It sounds like it is going south.
bugman is online now   Reply With Quote
Old 11-11-2012, 09:13 PM   #3 (permalink)
jimzpsd's Avatar
I replaced it already with a new unit from NAPA, and it still does this, almost seems like a loose or glazed belt slipping, but its not that either.
Old 11-11-2012, 10:17 PM   #4 (permalink)
bugman's Avatar
My Photos: (12)
Is the one from NAPA a new one or a new rebuilt one? I went through 4 from them on a car a few years ago before I got one that would actually work. They were fine at a low RPM but shut off at higher RPMS.
I would still take it to a independent shop that can test them out of the truck to make sure that it is working properly and from what it sounds like it isn't.
Old 11-12-2012, 07:38 AM   #5 (permalink)
badbart's Avatar
Just take it back and tell them the light is on, they'll swap it out.
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 11-13-2012, 09:17 PM   #6 (permalink)
jimzpsd's Avatar
I hear what you guys are saying, but its a brand new unit not reman., but "if" its the alt. (again), then why do my volt gauges read normal? At highway speed its putting out 14.3 volts, with lights, heat and stereo on,...... if the alt. is failing, wouldn't this batt. light come on after its just started up, and the gp's are sucking current?
Old 11-14-2012, 12:23 AM   #7 (permalink)
Jimzpsd,
There's a single spade connector with a white wire that plugs into the top of the alternator. Sometimes the wire will get damaged or the spade connector won't maintain a good contact which can trigger the battery light.
Hope it helps,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 353,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
K.N.94PSD is offline   Reply With Quote
Old 11-14-2012, 01:08 AM   #8 (permalink)
Once I was heading out to go hunting and I was 300 miles from home and coasting down hill and my battery light would come on but every thing told me the alt was still charging, so when I got into a town and stopped to get something to eat, I checked the wires going into the top of the alt and made sure they were good and tight with good connection, solved the battery light coming on problem.
1995 PSD F-350 4X4
97 motor installed.
DaveH. is online now   Reply With Quote
Old 11-14-2012, 08:37 PM   #9 (permalink)
jimzpsd's Avatar
Originally Posted by K.N.94PSD View Post
Jimzpsd,
Hope it helps,
K.N.
That was it..........thank you
Old 11-14-2012, 10:22 PM   #10 (permalink)
I'm glad to help out, and it's good to hear that we got to the bottom of the problem
