Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 08-30-2008, 09:28 PM   #1 (permalink)
sloate's Avatar
Batteries keep going dead
Last night I went to go to the store and my truck cranked slow, batteries were at 11.5v and got 5v when cranking, today i charged them up and cleaned the terminals, and fired right up. when i was putting the cables back on, I got a good size spark, looks like something is draining them when sitting. Are there any common issues with these trucks. Im thinking of pulling one fuse at a time tell the spark goes away. Or is there a more simple way to find the problem? Any ideas out there?
1994 F250HD, Single Cab XLT, 7.3 PSD, 5 Speed, 33in tires, level kit, straight piped! 12000lb warn, Canada made, 234000miles w/97 parts truck
1964 F350, 24v 5.9 Cummins not even close to broke in, New Nv4500, Turned Np205, Custom Dana 70s Front and Rear, Two 20000lb PTO winchs, 14' lift, 49" iroks!!, 97 PSD acc. with wire harness swap, 87 F350 frame (still sits in shop with fresh coat of JD green paint "Built Not Bought" 0 miles,
http://sloate.googlepages.com
The Most Powerful Diesel Engine in the World!
sloate is online now
Old 08-30-2008, 11:38 PM   #2 (permalink)
Glow plug relay stuck on?
'94 F250 supercab 4x4, original owner, 4.10LS, shimmed FPR, Tymar air intake, DP Tuners 80 Econo burn, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
nashvillebill is offline
Old 08-31-2008, 12:43 AM   #3 (permalink)
sloate's Avatar
That just may be it, i have had some problems with it in the pass, i just replaced the gp's but not relay, i will unhook it and see, i think i will replace it anyways so when it does get real cold out i can make it to school. more then likely it was the same one that it rolled out of the line with back in 94. May just have something to do with that melted gp wire.
Old 08-31-2008, 03:54 PM   #4 (permalink)
sloate's Avatar
Still cant find it? unhooked every thing i could think of and pulled every fuse! when it stops raining i will hook my cables back up and see how many volts i have and keep a eye on it to see how fast it goes down. any more ideas out there?
Old 08-31-2008, 05:47 PM   #5 (permalink)
STurbo90's Avatar
My Photos: (9)
how many amps is it actually drawing?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 08-31-2008, 06:56 PM   #6 (permalink)
sloate's Avatar
Im not sure, How would I check?
Old 08-31-2008, 07:46 PM   #7 (permalink)
Supporting Member
mattski's Avatar
To check amp draw you would have to install either a gauge or multimeter in between one of the batts and the cables. How old are the batts? Might be worth just getting them load tested to see if they're any good.
Mattski
97 F350XLT, CC, SRW ,LB 4x4, 4.10LS, E40D, genuine Tymar intake, Diamond Eye 3" DP- 4" back to 5"tip, Stage 1 inj, IDM mod, gutted EBPV, modded pedestal, TW 6 pos chip, 1.0 turbo, shimmed FPR, Dipricol Optix pyro, boost & tranny temp on A-pillar, Pioneer CD, SIRIUS Sat.
Next up: SD I/C, SD HPOP & tranny cooler
mattski is offline
Old 08-31-2008, 10:07 PM   #8 (permalink)
sloate's Avatar
Its drawing 175 mA, started unpluging things and i got down to 120 mA, it got dark out so i will look at it some more in the morning.
Old 08-31-2008, 10:14 PM   #9 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
I would start by disconnecting the alternator to eliminate a bad diode and power going to ground in it. Then there are two fuses under the hood number 1 witch is a 20 amp fuse for the audio power and then the last one is number 9 witch is a 20 amp maxi for the PCM. Those should be the only two that should draw power with the key off I believe. Also how good are your batteries? If they are getting low on power and if one is going bad they could be your problem.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 09-01-2008, 01:57 AM   #10 (permalink)
sloate's Avatar
I know my batteries are on there way out but i don't think it should be drawing 175mA i would think around 20mA. I was also thinking the alternator, i will give it a try and see what what happens, I would like to try to make my batteries last 10 more months tell I go home since I have a good set sitting on some battery tenders but dont think it will happen. If i do get a set i was thinking of getting some gel cells, would it be worth it? should I get red or yellow tops? I have a winch i use some time but no very often.
Old 09-01-2008, 11:53 AM   #11 (permalink)
I believe your batteries should be replaced.
Your batteries should have a couple hundred amp-hours of storage capacity. Let's simplify, and say they only hold 100 amp-hours (they actually hold a lot more). Now let's say your current drain is a full amp (actually yours is a lot less). The batteries should power the 1 amp load for 100 hours...but apparently they become discharged overnight.
So the batteries have a) a storage capacity issue (sulfated) and/or b) an internal short, inside the battery itself, which is discharging the battery. Either scenario occurs frequently, batteries have a finite life.
edit: this link has a good explanation of battery ratings and other good info Deep Cycle Battery FAQ
Old 09-01-2008, 02:04 PM   #12 (permalink)
MarkEkberg's Avatar
My Photos: (13)
175mA is not much of a draw. I am thinking you have at least one bad batt.
One thing that seems to always draw is the keyless module. That could be drawing more, but I would look at the batt's fist.
MarkEkberg is offline
Old 09-01-2008, 03:10 PM   #13 (permalink)
sloate's Avatar
how many volts should they have just sitting, they are gel cells, they have 12.50v and droped .03v in a day unhooked and droped .10v in a few hours hooked up
Old 09-01-2008, 07:31 PM   #14 (permalink)
sloate's Avatar
$160 later I got two new batts, cranks so much faster, Im going to let it sit for a day or two and see what the drop in volts are.
Old 09-01-2008, 08:55 PM   #15 (permalink)
if it still goes down---disconnect the hot wire to the alt at night---and see where the batts are in the morning---as that would point to the bad alt diode spoken of--those diodes can short three ways---
94_turbo is offline
