battery terminals constantly corroding - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 07:18 AM   #16 (permalink)
swampcreek's Avatar
Corrosion on battery terminals indicate leakage of the battery. Either your overcharging and boiling the batteries, or the batteries themselves are just plain leaky.
I work in high voltage substations, this is something we look for all the time.
1997 F-250 Supercab 4X4 XL Manual everything (I ordered it that way), DPP downpipe to 4" pipe exiting front of rear wheel. Tymar intake. Turbo life saver. Activator electric brake controller. Firestone rear suspension air bags, Bilstein shocks, Stancor 586-902 GPR, Edge evolution programmer, Class V receiver on rear, class III up front, Valair heavy duty stock clutch and single mass flywheel. 130,000 miles as of 2/11.
swampcreek is offline
Old 11-11-2009, 12:01 PM   #17 (permalink)
BigDieselBoy's Avatar
Good post and comments folks. My one suggestion is that corrosion might be a result of a bad terminal to clamp connection. Even when the clamp is tight and looks perfect, it is possible for the post and inner clamp surfaces to have a buildup of corrosion you can barely see in the form of a black sheen. One way to tell if there is a layer of corrosion there is to take a multimeter and read the voltage at the post, and then again at the clamp. If the clamp reading while the truck is idling is around 14 volts and the post reading is around 12, the alternator is creating juice but the battery isn't getting the full charge. The end result can be a failed alternator and or a failed battery. A good scraping and cleaning of both posts and clamps makes a huge difference.
BigDieselBoy is offline
Old 11-11-2009, 03:02 PM   #18 (permalink)
I have to agree with Jcart, i use the yellow tops as well, no poblem since they are not lead acid batts. I also smear di-electric grease all over the lugs and terminals just because.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
