Belt Squeaking-How do I stop this? Near Vacuum Pump Pulley - Diesel Forum - TheDieselStop.com
Old 12-31-2012, 02:38 PM   #1 (permalink)
I have noticed that my belt is squeaky near the vacuum pump pulley. I just changed the belt and I changed 1/2 of the vac pump (the rotating half) thinking it was the bearing.
But I narrowed it down to the belt as the squeak by spritzing the belt with windex to lubricate it breifly. If I do this, the squeak goes for about 20-30 seconds then comes back. If I squirt the Windex right before the belt hits the vac pump pulley it quiets it down immediately so I realize that's where the squeak is coming from.
Any tips? I would hate to get stranded.
What I drive:
Ford E350 PSD 1995 --- Fast Diesel 385k Upgrades-DIY Push Button Manual Shifting E4OD Computer-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
MB 300d Turbo Diesel 1987 --- Fast and nice to work on
GMC Suburban 6.2 Detroit --- SLOOOW!!!
777funk is offline   Reply With Quote
Old 12-31-2012, 03:13 PM   #2 (permalink)
S95
Good year Gatorback belts with the cross hatch ribs on them are about the only belts that dont squeal . did the vac pump re/re of front half include a new pully that still has the paint on it?
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline   Reply With Quote
Old 12-31-2012, 04:46 PM   #3 (permalink)
No I re-used the pulley (no pulley included with the vacuum pump).
What I drive:
Old 01-02-2013, 08:27 AM   #4 (permalink)
Any other tips just incase the Gatorback I just ordered doesn't do the trick?
What I drive:
Old 01-02-2013, 09:35 AM   #5 (permalink)
All your idlers, tensioner, and driven accesories turning freely? I've got over 300,000 miles on the factory installed serpentine belt and it's never squeeked. The WP, Alt & vacuum pump have all been replaced, but the idler, tensioner, P/S pump, & A/C compressor are still the factory parts. The new belt, tensioner, & idler I bought ten years ago are still under the seat.
We had a discussion on another forum couple years ago that the ribs on the serpentine belts wear, they actually drive on the sides of the ribs like a v-belt and after a hundred thousand miles are prone to slippage, but I'm not 100% convinced of that... but it very well could be true. It would stand to reason that on real high milage trucks the grooved pulleys could wear too.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline   Reply With Quote
Old 01-02-2013, 11:48 AM   #6 (permalink)
I need to check everything again, but I think so. The idlers and tensioner all have new bearings in them. Also, the alternator and vacuum pump have been replaced/rebuilt. I haven't checked the compressor or the p/s pump. It seemed like there was a little play in the p/s pump but no noises that I know of. If I squirt the belt it quiets down for a few seconds.
The belt is an o-reilly house brand. I notice that it's starting to fray on the side toward the front of the vehicle.
What I drive:
Old 01-02-2013, 01:36 PM   #7 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Make sure the pulleys are all in line. If the side towards the fron is fraying you may need to adjust one of them (typically the power steering pump pulley). Also make surethat the tensioner is not "leaning" inward towards the motor. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline   Reply With Quote
Old 01-02-2013, 09:27 PM   #8 (permalink)
Aha! I'd bet that's the bingo moment here. It's in that area (vac pump, p/s pump) that the squeak is coming from.
So that leads me to the next question... I didn't realize that the power steering pump/pulley could be adjusted. How would I do that?
What I drive:
Old 01-02-2013, 10:01 PM   #9 (permalink)
My Photos: (19)
Get a Power Steering Pump pulley puller/installer (I got mine a AutoZone) and use it to move the pulley on the shaft in the direction it needs to go (mine was shredding the first rib off the belt ... a bit more drastic than yours ... and I moved it about 2mm which solved the problem). Cheers!
Old 01-02-2013, 11:14 PM   #10 (permalink)
You must have used a pulley tool (^^^^^) to swap the pulley when you replaced the vac pump. Same tool should work on the P/S pump pulley. But are you sure you fully seated the vac pump pulley when you replaced the pump? Who knows, maybe on the new pump, it should _not_ be fully seated; maybe it's the one that's out of alignment.
madpogue is offline   Reply With Quote
Old 01-26-2013, 04:51 PM   #11 (permalink)
City Cruzer's Avatar
Is there supposed to be any movement on the PS pump pulley? Mine slides back-and-forth on about 1/16th to 1/8th of an inch. i've got that same squeal and I'ver replaced nearly all the pulleys, and the water pump, vacuum pump. incidentally, the squeal only starting happening after i put in the new water pump. I've take the belt of and reseated it and the noise is still there.. driving me nuts!
1996 Centurion C350 7.3L Powerstroke, Banks Transcommand, 3" SS Silver Line Down Pipe, front Air Lift bags, Local Remaned trans, Racer X Triple Billet TC, custom Racer X accumulator body, Rebuilt Turbo with Banks Wheel and 1.00 Turbine, Isspro boost, Pyro and Trans gauges, 3 Gauge Piller pod, Fumoto oil drain valve, Straight piped exhaust, DIESELSITE 203* Thermostat, Replaced PCM (true TDE1), Banks Stinger Plus Chip, EBPV delete
City Cruzer is online now   Reply With Quote
Old 01-28-2013, 07:53 AM   #12 (permalink)
S95
my PS pulley moves at least that much.....its the only one that "self aligns". no squeaks from my belt.
SD STARTER
