Is blockheater standard on all PSD's ??? Is install very hard??
I recently bought a 97 F-250 HD 4X4 Crewcab and have not added to my sig yet. Question is do these year of trucks come standard with a block heater or is it an aftermarket item? I have not found one yet!
Are they very hard to install? Also are their any links with good instructions/illustrations. Thanks.
Re: Is blockheater standard on all PSD's ??? Is install very hard??
I believe on the 97's block heater was an option?
You can tell by looking at the top of the oil filter, on the filter mount there will be a wire harness connected to it if it has the heater, then just follow the wires.
The heater was included with the PSD option in 1997. Its is hard to find the plug. The dealer could not find mine when I bought it. I later found it. It should be on the drivers side behind the grill.
1997 F350 3" down pipe, F6 Dp-Tuner, and gauges 170,000 miles, extra 65 Gal fuel tank from Transfer Flow
2001 E350 135,000 miles, F6 Dp-tuner
[/ QUOTE ]You might want to recheck your information. It was a option on the 97's and not all of them came with it. Usually if the truck was ordered by a dealer in a southern state it did not come with a heater. I'm not sure of where the cut off line was but not all 97's have them.
would you buy a replacement block heater from ford or another source. mine makes a little noise but does not heat up. i want to replace it
I found my heater and both it and the cord are bad. I bought a whole kit, heater cord and all from one of our sponsors for $33.27 plus shipping. Mine is a 94-97 type heater but I think they have newer years also. It was powerstrokeshop.com and the part number is PSM/3500043. I will try to put a link into but not sure I can.
I got the heater pretty quickly and it seemed like a very high quality heater and cord. Took me only about 30 minutes to change it and it works great. Thanks Powerstrokeshop!
1997 Ford F-250 Heavy Duty crewcab 4X4 shortbed, PSD, 3.55 LSD tow pack! 3" downpipe straight into 4" exhaust system with Walker BTM. Pyro, tranny temp gauges. 203 thermostat. Viper Alarm system. 342,000 miles. Custom made frame Hitch with D rings, hidden gooseneck ball, bedliner
2000 Keystone Springdale T.T. 29 1/2 feet, 8000# fully loaded.
Jim
[/ QUOTE ]My 97 did not come with a block heater! [img]/ubbthreads/images/graemlins/grin.gif[/img]
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
