Brake Bleeding Order - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 08-18-2007, 11:29 PM Thread Starter
My Photos: (10)
I had to replace a caliper today and I replaced a leaky MC.
In what order should I bleed them?
I am not exactly sure how to bleed an MC, but here is how I was planning on doing it. Fill it up with fluid until it is leaking out of the holes, and then hook up the fittings. Then press on the brake pedal while opening the fittings up again.
What am I missing? This is my first MC replacement.
Kurt
SOLD!!
1997 F350 XL PowerStroke 4WD, ZF-5 w/ South Bend Con OFE Clutch
Regular Cab, Long Bed, SRW, 3L55's, Bilstein shocks, Warn premium hubs
3-inch downpipe/4 inch exhaust w/ Magnaflow muffler and cat
Tymar intake
International Water Pump with integrated filter
Wildman Four-Position Chip; Baby Swamps; D66 turbo with 1.00 housing; SD HPOP
Isspro EV Boost and Pyrometer gauges
285/75R16 E-Rated BFG All Terrain KO's
Rear Disc Brakes from Blackbirds Custom Trucks
spaceballs is offline
post #2 of 8 (permalink) Old 08-19-2007, 01:11 AM Thread Starter
My Photos: (10)
Re: Brake Bleeding Order
OK, I need to bleed everything...front calipers, rear calipers, and the MC. I know that I do the rears before the fronts, but where does the MC fit into all of this?
Kurt
SOLD!!
Tymar intake
post #3 of 8 (permalink) Old 08-19-2007, 01:48 AM
Fill it up, start at your farthest brake away from the MC and bleed it(right rear). Then just work your way closer. You may end up having to do it twice.
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
bosefes is offline
post #4 of 8 (permalink) Old 08-19-2007, 02:06 AM
The MC should be bled first. There are kits available to help with this. Otherwise you end up pushing all the air into the rest of the brake system and it will take a while to get it all removed.
Mitch Peterson, Snohomish, Wa.
96 F-250 SC XLT 4x4 PSD E4OD with Sonnax valve & Tricumulator springs, 4.10LS, Tymar Intake, Downpipe from Stan's Headers, Superchip 60/110, 10K Resistor, Ride-Rite Air Bags, Hayden Cooler, Bilstens, Isspro Gauges, pillar mount, Fumoto Valve, Fillnecks gutted and vented.
04 Jeep Rubicon
10 Polaris 800 Dragon
03 Polaris 800RMK Vertical Escape.
Registered 7/99
Mitch P. is offline
post #5 of 8 (permalink) Old 08-19-2007, 08:28 AM
Excavator's Avatar
My Photos: (11)
Here is how I bleed a new master cylinder.
Read this article
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #6 of 8 (permalink) Old 08-19-2007, 01:50 PM Thread Starter
My Photos: (10)
I dropped it off to get bumped with a power bleeder. My old lady didn't want to spend part of the afternoon wearing her leg out on the brake pedal.
Kurt
SOLD!!
Tymar intake
post #7 of 8 (permalink) Old 08-20-2007, 01:52 PM
milner351's Avatar
My Photos: (5)
if you anticipate a lot of brake work in your future, buy one of the power brake bleeder kits that is essentially a bug sprayer with some adaptors to clamp a lid over the different designs of master cylinders.
I paid $60 for mine off ebay as I recall, and it's been a godsend, especially on hydraulic clutch set ups, and on large brake systems like our trucks have.
You can fill the resevoir in the master, put some fluid in the power bleeder, pump it up, then start at the pasenger rear and work your way forward without another person - and it's QUICK! You can flush all the old fluid out of a typical vehicle in about 15 minutes.
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
post #8 of 8 (permalink) Old 08-20-2007, 02:14 PM
BlueMule's Avatar
My Photos: (12)
if you anticipate a lot of brake work in your future,<u> buy one of the power brake bleeder kits </u>that is essentially a bug sprayer with some adaptors to clamp a lid over the different designs of master cylinders.
Or you can make your own pressure bleeder like <u>THIS</u> [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Rodney#33
BlueMule is offline
