Brake Caliper Slide Shims - Diesel Forum - TheDieselStop.com
Old 01-25-2009, 07:50 PM   #1 (permalink)
Question Brake Caliper Slide Shims
I've noticed that since I replaced my front brake calipers with OEM Ford/Motorcraft remanufactured units a few years ago, I've been getting a clunk noise from the passenger side of the truck when the suspension cycles. I've examined that side of the truck and determined that there's a fair amount of slop (~1/16") between the caliper slides and caliper mounting bracket slides, causing the clunk. So, I'm guessing Ford's caliper reman contractor didn't check the dimensional specs of the caliper they remanned, and I ended up with the result.
I've heard that there's shims available in the aftermarket to correct this situation, but I haven't had any luck finding them. So, if anyone has any recommended part numbers or suppliers for the shims, please let me know.
Keep in mind that my truck is a 94, so its calipers use the older split steel and rubber slide pins; not the bolt, sleve, and boot type on the 95-up PSDs.
Thanks,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Mickey Thompson Baja ATZs, 339,000 miles, Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
K.N.94PSD is offline
Old 01-25-2009, 10:46 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
I've never had that particular problem on mine (knock-on-wood). Have you tried new slide pins (I'm thinking you probably have)? Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 01-26-2009, 08:57 AM   #3 (permalink)
Craig Alberts's Avatar
Ah...the dreaded "clunk" from the left side near the front of the truck. This issue has plagued Ford truck drivers for years. There is no one particular item that causes it. Everything from frame rivets to loose fender mount bolts and everything in between...
Hopefully just installing shims will help you eliminate yours...but if not, do a search on here for "clunk" and begin the odyssey that many of the rest of us have been through to help eliminate one of the great mysteries of our time.
Craig Alberts - 1995 F350 4x4 CC L/B, 195,000 miles, 4.10's, MONSTER BOX E4OD, Intercooled, PacBrake, RS 9000's, Weld Sidewinder Wheels, 35x12.50R16.5 Big-O, Velvet Rides, TYMAR open filter, Ruenel bumpers all around...
Craig Alberts is offline
Old 01-26-2009, 10:48 PM   #4 (permalink)
Thanks for the replies Patrick and Craig.
Patrick, I installed new Motorcraft pins when I replaced the calipers a few years ago. They still look good, but I suppose new pins could help.
Craig, luckily, I know where the clunk is coming from, the problem is finding the shims to correct the issue.
So, if anyone knows of a source for shims to correct the worn slides, it would really help.
