Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-07-2008, 10:54 AM   #1 (permalink)
Broken spring hanger
I have a broken, farthest to rear spring hanger on the drivers side. My questions are, where is the best place to buy a new one? Has anyone ever changed one, and what is involved? Any help would be appreciated.
96 F250,4wd, Extended cab, auto, pretty much stock.
Black19 is offline
Old 07-08-2008, 07:11 AM   #2 (permalink)
Bump one more time. My rear leaf spring is sitting on the underneath of the bed and I can't drive it. Anyone ever change the spring hanger on a O.B.S?
Black19 is offline
Old 07-08-2008, 08:43 AM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I had to take it apart when I did leaf springs. There is not much to it. As far as replacing it I am fairly certain it will be a dealer only part.
MarkEkberg is offline
Old 07-08-2008, 10:18 AM   #4 (permalink)
Once you have jacked up the truck and removed the spring eye bolt you will see that the hanger is riveted to the frame. Cut off the rivet heads using a torch or air tool etc then using a punch drive out the rivets. The hanger will now be loose. The new or repaired hanger can now be installed using nuts and bolts.
The hangers are i think a dealer item.
Cheers.
Brian.
94 PSD. Supercab, LB. 5spd.
Autometer oil & coolant temp gauges.rancho 9000
shocks.Smitty tube step bars.Pulsetech battery
maintainer.Rhino spray on box liner.Towing mirrors.$20 exhaust brake.Inside/outside thermometer.Radio shack CB.Still a building.LUK single mass flywheel and clutch.DIY oil bypass filter.DIY air filter.
Brian Cloke is offline
Old 07-08-2008, 11:16 AM   #5 (permalink)
Son broke the same hanger on His '93 F-150 Lightning about 6 months ago....it's a common enough problem the local dealer had them in stock. Rust takes a toll on these trucks in places You wouldn't expect!
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
294,000 mi & NO Problems, LUK Clutch, and the Cat is buried in the back yard!
Dr.Evil is offline
Old 07-08-2008, 03:11 PM   #6 (permalink)
Thanks guys...Yes it is a dealer only part and they did have them in stock. About 70 dollars a piece. I have a project to do now. Thanks for the info, I was unsure about the rivets. I will buy hardened bolts and get to work. The other one is cracked so I am going to do both. Thanks again
Black19 is offline
