Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 02-21-2007, 12:50 AM   #1 (permalink)
bypass oil filter
What kind of bypass oil filter system is most everyone using. Is it possible to buy a remote filter and do it yourself and just buy the filter? Where on a 1996 PSD do you tie in on the supply and return on this filter?
stevemiller is offline
Old 02-21-2007, 01:18 AM   #2 (permalink)
Send a message via AIM to rockets10510
Re: bypass oil filter
i did my own here is a link to my pics. http://www.bscontracting.com/images/
anthony
1997 Ford F350 2WD SRW White Crew cab 260,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, diesel site 6 pos chip. B & W turn over, coolant bypass filter.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
1997 Ford F350 2WD SRW Green Crew cab 236,xxx miles, AFE exhaust, oil bypass, coolant filter, intercooler, 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 02-21-2007, 09:53 AM   #3 (permalink)
I did my own. It took about 20 minutes. Ports for doing supply and return are on the same side of the engine as the main engine oil filter. I used the Racor Bypass because I can get Racor products for about %50 off retail
1990 Jeep Wrangler with tons of mods
1995 F250 5spd turbo Diesel for towing the jeep
RedPenguin is offline
Old 02-21-2007, 10:03 AM   #4 (permalink)
tjbeggs's Avatar
I am current running a full flow/bypass combination filter made by Fleetguard. IT incorparates a bypass filter into the full flow filter. I just starting useing them but seem to be working very well. I will also be installing a baldwin b164 filter with the correct base as another bypass filter.
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 02-21-2007, 03:48 PM   #5 (permalink)
My Photos: (5)
tjbeggs - what is the part number for that combination filter your running?
Belleville, MI (Detroit / Ann Arbor)
'97 F250 4x4 7.3PSD ZF5spd 4L10
PA2818 diy intake, wicked wheel diy turbo rebuild, .84 turbo housing, no muffler, I LOVE MY BEANS TS'ers! ;-), new pedal box bushings, Fleetgaurd coolant filter, Seat Mod, electric fan, Eagle 16x8 w/265 75 Firestone Steeltex AT, cooling pkg front bumper
'69 Mustang 428CJ(ongoing project)
'99 escort zx2 commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
Old 02-21-2007, 04:09 PM   #6 (permalink)
tjbeggs's Avatar
lf9027 I have some for sale down in the classified section under "other Items" I had to buy a case of 12 and can't use that many in a reasonable time so I am just selling them what I bought them for to get some of my money back out of them. PM me if you want to try one (or two!!)
Truck Pics
tjbeggs is offline
Old 07-31-2008, 01:25 AM   #7 (permalink)
How is the Fleetguard Venturi been working for you? Have you compared it to Baldwin's dual flow? How about to a Donaldson bypass?
2000 F-250 7.3L Powerstroke. Build date 08/99.
snakyjake is offline
Old 07-31-2008, 11:45 PM   #8 (permalink)
I use a venturi combo along with a seperate fleetguard bypass. I only use the seperate bypass because I had it set up already before I learned of the venturi combo. I do pretty regular oil analysis. I usually run 10,000 miles on texaco mineral oil and generally only see .3% insolubles. I don't know how much of a gauge this is but I can usually still see through my oil on the dipstick when it's warm when I change it. I use the LF9691 oil filter which is larger than the stock filter but still fits on the filter base just fine. It's probably about a quart larger in capacity I would guess.
'94 F250xlt ext. cab. ZF5-speed 4x4. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. LF777 bypass oil filter. Electric fans. 70 psi fpr. 10k mod. 1.0 turbo housing. Boost blanket.
sdan27 is offline
