A/C Hose Problem! - Diesel Forum - TheDieselStop.com
Old 06-04-2009, 02:40 PM   #1 (permalink)
Angry A/C Hose Problem!
All right. Thirteen years and it finally quit blowing cold air. Who can complain? I added more freon but the connector on the high pressure hose is the leak. There is no Schrader valve. Just a stupid POS ball valve. You can't change this! Is there a fix anybody has short of replacing the whole hose assembly? I mean that also means a new drier, vaccum and may as well do the expansion valve while I'm in there! Couple of hundred bucks out the window for this little leak. Thankfully I have freon. Anybody's help would be most appreciated!
1996 F250 Crew Cab "Mean Green" 24 inch "Bullet" resonator, Superchips Power Programmer, K$N Air filter,crossed-drilled and balanced rotors, super duty pads,Detroit locker with 4.10 gears,24" front cooler, 24" frame rail cooler. Pioneer receiver with 6 disc changer, two 10" JL Audio subs,Kenwood 600 watt mono amp, Pioneer four channel amp pushing Pioneers in the doors.
Txfishermn is offline
Old 06-04-2009, 10:01 PM   #2 (permalink)
for an a/c system that has never been touched it probably wouldn't be a bad idea to change out the accumulator ( I think the ford trucks have an accumulator rather than a receiver/dryer, also i think the ford trucks have an orifice tube rather than an expansion valve ). not that anyone actually does it but i think most manufacturers recommend replacing the accumulator every couple years. you could possibly check out a thermo-king dealership or any other place that specializes in a/c work and they might be able to hook you up without having to replace the hose.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
