A/C suddenly quit- any ideas? - Diesel Forum - TheDieselStop.com
Old 08-02-2008, 09:21 PM   #1 (permalink)
I went on a trip that is about 8 hours and the a/c was icy cold- then when I came back to the truck a week later it does not work at all. Can anyone tell me where to start checking. I do not think the compressor is kicking on at all but I will try to verify that first.
1994 F250, Tymar, Tuff country 2" lift
lomile94 is offline
Old 08-02-2008, 09:30 PM   #2 (permalink)
bugman's Avatar
My Photos: (18)
Make sure that the compressor is working. I had the top connector go open on mine last year. If you wiggled it it would work for a while and then quit. If you can find the right dealer there is a aftermarket connector for it or you may try the one for the 99+ years.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 08-02-2008, 11:09 PM   #3 (permalink)
ammayernick's Avatar
Just replaced the connector on mine as well. Bought it direct from Ford's aftermarket supplier. Can get you part # if that helps.
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps * http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 08-02-2008, 11:38 PM   #4 (permalink)
I had the same problem with the connector on mine, I just moved it around until it started to work, been working fine for two years without anymore problems.
1996 F-350,CC,LB, Rebuilt Tranny,Billet Trq conv,shift kit, AFE Stage 2 intake, 3' dp, 4''Diamondeye exh with flow through muffler, 35"BFG's,no lift,new engine wiring harness,new fuel heater(dealer fixed due to a short before I found this site,knowing what I know now I would have just unplugged it),new glow plugs at about 145,000 mi,balljoints,bearings,rotors,all new steering linkage,GPR,powersteering pump,steering wheel bearings,IDM mod,rebuilt turbo and gutted EBPV and pedestal,just over 175,000 mi,
Big Jeremy is offline
Old 08-03-2008, 07:48 PM   #5 (permalink)
the compressor is not kicking in - and wiggling the connector makes no difference. There are two connectors on top- which one and how do I test it? Is there a way to tell if the compressor clutch is bad? Is it easy to change?
lomile94 is offline
Old 08-05-2008, 03:00 PM   #6 (permalink)
Test resistance across the two terminals to test. Good should be about 1 ohm or so. If you have resistance, see if you have voltage at the connector with the ac on.
If there is no voltage there, then you have a bad switch, or low freon (or bad wire, etc.). If open circuit across terminals, then bad clutch. If there is voltage and resistance, the clutch itself may be bad. It might be possible to readjust, although it's probably shot.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 08-05-2008, 09:52 PM   #7 (permalink)
The resisitance is 3.4 ohms and there is voltage- what now? Clutch coil is probably good,right? How to test clutch- do I need some kind of puller to change the clutch?
lomile94 is offline
Old 08-06-2008, 09:45 AM   #8 (permalink)
That's probably a good coil. You need to check ground as well. You have voltage and ground at the plug, and a good coil - so the only conclusion is that the coil is engaging but the friction material for the clutch is missing enough that it's not engaging the compressor.
There's a nut at the middle of the clutch. You need to pull the bolt out and disassemble the clutch. There may be some shims in it that can be removed to get it to work, but it will probably fail again soon. I would just get a new clutch.
When the clutch is engaged, it is supposed to move the outer plate .080, IIRC.
Does that make sense?
1996 Town Car
Old 08-06-2008, 12:34 PM   #9 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Before you tear into the compressor buy a $30 gauge to see if you are low on r134a.
I would start there.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 08-07-2008, 07:46 AM   #10 (permalink)
I believe that there would be no voltage to clutch coil if it was low on refrigeranr, right? My understanding is that the pressure switch must prove refrigerant pressure or the voltage will not be sent to clutch coil? Somebody please correct me if this is not right.
I will dissassemble clutch next. BTW- there is very noticeable play in the clutch.
lomile94 is offline
Old 08-07-2008, 08:58 AM   #11 (permalink)
Correct. If it's low on refrigerant, it would either have the compressor engaged or not have voltage to the clutch. You have a compressor cycling switch that is a NO switch, and does not close until a certian pressure is reached. It's on the return line located at the back of the compressor.
Please explain the play in the clutch. Does the face of the clutch have up and down movement? That's likely a bad front bearing in the compressor. I have the same problem in mine currently.
1996 Town Car
Old 08-07-2008, 09:11 AM   #12 (permalink)
He can't check the pressure until he gets the compressor running.
1996 Town Car
Old 07-02-2009, 08:31 AM   #13 (permalink)
SoB
SoB's Avatar
If any body has the part number and source handy for the compressor plug wire that would be great.
Thanks Steve
Black '96 F250 XLT 4x4 SC,LB,7.3L PSD,Suncoast E4OD,3:55 Gears,Tymar Intake,4"exhaust,Hypermax intercooler,H2E,CPR Fuel,DIY StageII's, Wildman 4 position chip,Tymar HX mod,Adrenaline HPOP,Ranch Hand Bumpers F&R, Warn 12000LB Winch,305 70R16 MTR's,Oil,Tranny&Pyro pillar mounted, 328K
SoB is offline
Old 07-02-2009, 09:12 AM   #14 (permalink)
Thanks Steve
Ford. $15, IIRC.
1996 Town Car
Old 07-03-2009, 12:02 PM   #15 (permalink)
i just charged the ac of my explorer, the clutch did not engage until i opened the valve off the 134a can.
firman is offline
