cab lights - Diesel Forum - TheDieselStop.com
Old 05-06-2009, 10:58 PM   #1 (permalink)
french2's Avatar
Question cab lights
Anybody know where the cab light on a 1997 psd hook up at
1997 f250 xlt psd auto long bed dual 6" black stacks tymar intake and 6 position on the way 4x4
135000 mmiles on engine and trans
205000 miles on body and rear end
french2 is offline
Old 05-06-2009, 11:41 PM   #2 (permalink)
pass side kick panel....right above your floor mat on the right side there is a panel...take it off there is a plug that is mounted to the side there that is not running to anything that is it....your hot wire should be a brown wire...trust me i just put 99+cab lights on my truck 2 months ago.
1997 F-250 PSHD 4X4 Off Road CC SB 7.3L --211,000 miles, 3" Down pipe-4" straight exhaust to 6" tip, K&N Air Filter, EDGE-- EVO-3 Stage, Re-built E40D with shift kit (high flow oil line, heavy duty clutch plates)...gauges to come real soon!...other wise bone stock for now:evil
http://i93.photobucket.com/albums/l7...Picture050.jpg
deiter5262 is offline
Old 05-06-2009, 11:53 PM   #3 (permalink)
97dyer's Avatar
My Photos: (6)
I'm not sure if you already have the lights but I ordered mine a few months back from class8truckparts.com and they were just like the stock ones for '97's and cost me $33 total including shipping. Good luck with them, I like the looks of them alot. I spent most my time not on the lights but taking all the trim parts off and such on the inside.
1997 F350 Crew Long, XLT, 4x4, 7.3L Diesel, 4.10 LS, 5 Speed, 108K Miles, Add-A-Leaf in Front, Firestone Air Bags in Rear, 16x8 Ultra 164 wheels with 285/75/r16 Pro Comp Extreme tires, 3" DP 4" Diamond Eye Exhaust, Tymar Air Intake, Auto Vent-shade Window Visors, Husky Floor Liners, Pro Tech Headache Rack and Tool Box, Custom Rails, Line-X Bed Liner, JVC CD Player, Full Diamond Plate Tailgate Cover and Bed Caps, Cab Lights Added, Cobra 25 LTD CB Radio with Max Rad Antenna, Carling switches, Wheelskins steering wheel cover.
97dyer is offline
Old 05-07-2009, 07:32 AM   #4 (permalink)
french2's Avatar
ok thanks does anyone now where i can get 2 f350 emblems to put back on the grarter panles
french2 is offline
Old 05-07-2009, 10:51 AM   #5 (permalink)
97dyer's Avatar
My Photos: (6)
fordemblem.com has some, but maybe someone else knows where they are cheaper.
97dyer is offline
Old 06-01-2009, 07:53 PM   #6 (permalink)
Mine are not working. Just got the truck and I don't see any switch to turn them on with. I assume they are supposed to come on with the headlights? Is there a fuse or anything I should check for?
Fossil is offline
Old 06-03-2009, 07:48 PM   #7 (permalink)
Anyone?
Fossil is offline
Old 04-15-2011, 02:10 PM   #8 (permalink)
Fossil, been a couple of years since you posted your question but I just got a '96 f250 with cab lights and mine don't work either. Bulbs are replaced. Did you find a solution to get them on? Maybe I am missing a switch somewhere??
xbrotherx is offline
Old 04-16-2011, 11:30 AM   #9 (permalink)
Everyone of my bulbs where shot. I had to replace them all. They have worked fine ever since.
Fossil is offline
Old 04-17-2011, 09:10 AM   #10 (permalink)
Great! That's good to know. I was starting to worry there was something more sinister lying below that would cause my lights to not work. Thanks.
Old 04-17-2011, 11:20 AM   #11 (permalink)
No separate switch for the cab marker lights, they come on with the parking lights thru the normal headlight switch. I think they're even on the same fuse as the parking lights.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
