Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 10-04-2008, 03:28 PM   #1 (permalink)
Changed oil rail plug - no start
My dad and I just finished changing his rear passenger oil rail plug to fix a leak and now the engine doesn't start. Does the oil rail need to be bled?
hipostang01 is offline
Old 10-04-2008, 03:58 PM   #2 (permalink)
Supporting Member
bugman's Avatar
My Photos: (15)
It will take a lot of cranking to refill the oil passages back up to get that side to want to fire up. Check your high pressure oil pump and make sure that it is full. Then after it starts it might run rough for quite a while. The best way to get it to smooth out is to take the truck on a 30 mile drive at freeway speeds to bleed all the air out of the lines.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
bugman is online now
Old 10-04-2008, 09:13 PM   #3 (permalink)
blageurt's Avatar
It took like half an hour of cranking with breaks in between as not to fry the starter before I started mine when I did my Injector o-rings and I filled the rails up before. As Bugman said you need to go for a good cruise at a prolonged 2000-3000 rpm to bleed all the air out of the system . . . Just take it easy on the starter and make sure batteries are fully charged.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 10-04-2008, 11:11 PM   #4 (permalink)
Thanks, we got it started.
