I see lots of post about certain codes being checked. How do I check codes short of stopping by my local (greedy!) Ford dealer? Is there an instrument that I can buy? My check engine lite keeps coming on. I have a strong fuel smell and see fuel on my intake manifold vicinity of fuel filter. Will this cause the check engine lite to illuminate?
Thanks! Art
the only way is with a scanner or a programmer.i have an edge evolution programmer and it will pull codes.
96 f350 powerstroke 5 speed manual tranz. crew cab extended cab long bed dually and yes you read this right.mods 3"downpipe,4"exhaust,gutted ebpv,tymar air intake,water temp, boost guage,egt guage on a-post,shimmed fpr,Stage-1 diy injectors,beans 6 position chip,and looking for new things to try for more power!!!!
best thign to do is find a guy local to you that has some more experience with these and a scanner, your fuel issue/leak will not cause a CEL so they are not related, a can of brake clean with fix teh fuel problem, then jsut trace the leak.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
Is there any software I can get for my laptop that will let me check codes?
longrthnu2, what is the "Edge Evolution Programmer"?
Nit, sounds like you're recommending that I clean allof the old fuel up with brake cleaner and then see where the fresh fuel is coming from... right?
Anybody in Eastern CT or RI that has a scanner? I'm buyin' lunch!
Art
Jim Sult / Excavator (we dig it)
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, BabySwamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
i agree with excavator, i have AE myself and would be lost wthout it, and its very easy to use.
2002 F-350 4wd psd. hx 48 turbo, single shot injectors, dual stage nitrous, 4 inch duals, 3 pos custom tuned dp chip,ccv mod, aih delete mod,itp regulated return, oil crossover line, sp diesel 10 level kit, afe stage 2 cold air kit, and many other mods and inventions made to engine. monstorbox tranny,triple disc tq, ladder bars, 4 inch susp lift, dick cepek tires on american racing rims and beadlocks, Ford AIC, Auto Enguinity.Billet Badges, custom badges.F-444 Gettin' Stroked
White 2-180 3208 cat
Massey Ferguson 35 3 cyl perkins
Massey Ferguson 6180 6 cyl perkins
Massey Ferguson 255 4 cyl perkins
Massey Ferguson 65 4 cyl perkins
Agco LT-75 4 cyl Cummins
Case 1845C Skid Steer 4 cyl cummins
Case 580 construction King Backhoe 4 cyl case
1986 F-250 6.9 IDI 4x4 265,000 miles *sold*
1994 4wd f-250 ext cab psd
