code po236 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 07-06-2009, 01:33 PM Thread Starter
code po236
Had transmision rebuilt truck ran fine for a week. Pulled our boat lasted 20 miles started shifting hard and overdrive light was flashing. Took back to the transmission shop and they claim its not a tranny problem code po236 comes up what do I do now. Its a 1997 psd with 182000 miles.
fred B is offline
post #2 of 6 (permalink) Old 07-06-2009, 02:17 PM
STurbo90's Avatar
My Photos: (9)
the 236 code is for the map sensor.
the map sensor is on the passenger side of the firewall. It has the vacumn hose going to it from the intake manifold.
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #3 of 6 (permalink) Old 07-06-2009, 02:32 PM Thread Starter
Is the map sensor probaly the problem? Checked the vacuum hose it was not clogged. Like I said my overdrive light is flashing and the truck shifts really hard. It seems like it is using more gas.
fred B is offline
post #4 of 6 (permalink) Old 07-06-2009, 05:20 PM Thread Starter
Had another mechanic scan it. Came up with codes p0236,p0237 and p01728 witch is a trans shift malfunction. Taking it back to the transmission shop. The truck shifts hard from first to second and the overdrive light is blinking. Any more suggestions would be appreciated.
fred B is offline
post #5 of 6 (permalink) Old 07-07-2009, 11:54 AM
I had a bad barometic pressure sensor. It caused the same type of symtoms. OD light flashing and hard shifts.
1997 F 250 BONE STOCK 305,000 MILES
Jmikan is offline
post #6 of 6 (permalink) Old 07-07-2009, 03:04 PM
91diesel's Avatar
It better not be using ANY gas!
sorry, just had to
91diesel is offline
