Code reader for PS Diesel - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 01-03-2008, 10:41 PM Thread Starter
Does anyone know of an affordable (less than $100) diagnostic trouble code reader that I could use on my 96 F250 w/ PSD? I was looking at the OBD2 readers for use on 96 and new vehicles, but realized that my truck is exempt from OBDII requirements and was told these readers would not work. I was told I would need a high end reader from the OEM to be able to read codes from the engine in this truck.
Thanks..
96 F250
Banks down pipe
Tymar Intake
Warn Manual Locking Hubs
Tru Control Brake Controller
bigcamper325 is offline
post #2 of 15 (permalink) Old 01-04-2008, 08:32 AM
Re: Code reader for PS Diesel
96 is fully OBDII compliant. You want something that plugs into the port under the dash.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
post #3 of 15 (permalink) Old 01-04-2008, 09:18 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 82FordTruck</div><div class="ubbcode-body">96 is fully OBDII compliant. You want something that plugs into the port under the dash. </div></div>
No, it is not. The valve cover has a sticker that reads "OBDII EXEMPT"
Cheaper code readers will physically plug in, but will not read codes on the 97 and older trucks.
Something like AutoEnginuity can be bought with the enhanced powertrain package for about 350 bucks and loads to a laptop. I have this and it works great. It also allows KOER and KOEO tests.
Jerry
Black 2010 Ford F250 XLT Crewcab Longbed 4x4 6.8L V10. Special Ordered. 295/70r18 Nitto Terra Grapplers on black powdercoated stock wheels, Harley Davidson Edition headlights. FX4 Grille. Recon smoked cab lights and mirror lenses. Factory bumpers and nerf bars have been powdercoated black.Husky Mudflaps,custom black 4" exhaust, AirAid intake, X3 tuner from 5 Star Tuning, AutoVentShade door sill protectors. Soon will black out the badges.
Jerry Miller is offline
post #4 of 15 (permalink) Old 01-04-2008, 09:46 AM
Jerry, thanks for correcting that. I did not know that. I have also used a friends AutoEnginuity program and highly recommend it.
1996 Town Car
post #5 of 15 (permalink) Old 01-04-2008, 10:19 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 82FordTruck</div><div class="ubbcode-body">Jerry, thanks for correcting that. I did not know that. I have also used a friends AutoEnginuity program and highly recommend it. </div></div>
No problem. I just wanted to make sure no one went out and bought a reader that wouldn't work and couldn't be returned once opened.
Jerry
post #6 of 15 (permalink) Old 01-04-2008, 10:26 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mad_Stacker</div><div class="ubbcode-body">[quote=82FordTruck]Cheaper code readers will physically plug in, but will not read codes on the 97 and older trucks.</div></div>
They work on my '97. Should that read '96 and older maybe?
Snowtow is offline
post #7 of 15 (permalink) Old 01-04-2008, 11:09 AM
MarkEkberg's Avatar
My Photos: (13)
Cheap ones do not work on mine. Only thing I have seen work is the snap-on versions.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
post #8 of 15 (permalink) Old 01-04-2008, 02:01 PM
The edge evolution reads my codes. it's not under $100.00 though
1996 F-350 psd crew drw, demuffed, fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member &lt;img src="/ubbthreads/images/graemlins/smile.gif" alt="" /&gt;thanks Matt!! Stancor gpr (12/26/07) Coolant filter (11-1-2008) Relocated Block heater plug (1/01/2011) Tranni by JOHN WOOD (12-08-2009) Thanks JOHN more mods to come.
fordmedic is offline
post #9 of 15 (permalink) Old 01-04-2008, 02:09 PM
You need something with enhanced ford capability. Check out http://www.obd-2.com This is software only and will need a computer to run it. It comes with a usb adapter to plug into the port on your dash.
95 F350 psd stage 1s, wildman chip
DeezelDriver is offline
post #10 of 15 (permalink) Old 01-04-2008, 03:44 PM
ohiopsdx17's Avatar
So if my truck is a 97 and I put it into that site I don't get the powerstroke selection. but if I put it in as a 96 I do??? what about the ELM scan 5's will they work
Field Service Technician For Godwin Pumps.. College Degree In Heavy Duty Diesel and Power Generator Systems
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed. -4" Suspension Lift - 4" exhaust - 3" Downpipe - 5" Stacks - 10Kmod - Shimmed FPR - Home made air intake - Rosewood Stage 1's - TS 6pos Chip - 4:10 gears - Valair SMF conversion - Currently getting a frame off resto
2006 F-250 Lariat CCSB - 4" Turbo Back - Suprchips tuner - Rust Free from florida
ohiopsdx17 is offline
post #11 of 15 (permalink) Old 01-04-2008, 04:41 PM
that's essentially what the AE software mentioned above does as well.
1996 Town Car
post #12 of 15 (permalink) Old 01-04-2008, 07:13 PM
Snowtow,
Is your truck a 49 state truck or a California truck. Cali's OBDII law required vehicles with a 14000 pound GVWR and under to be compliant, whereas the 49 state OBD is for 8500 pound and under.
Jerry
post #13 of 15 (permalink) Old 01-07-2008, 02:44 PM
It's a 49 state, at 8800 GVWR. It is OBDII.
Snowtow is offline
post #14 of 15 (permalink) Old 01-07-2008, 07:53 PM
On my valvecovers, it says OBDII Exempt. I'm looking into the autoingenuity software
1997 F-350 XLT Regular Cab. 4x4. 7.3 Powerstroke. Auto. All Stock.
2001 F-350 XLT Regular Cab. 4x4. 7.3L Powerstroke. Auto. 3.73 gears. Tymar. 10k mod. DR 2" Leveling Kit. 285/75 Bridgestone Dueler Revo AT's. Powerslot Cryo'd/LTS brakes. Custom Salt And Sand Paintjob Thanks To Winter
ChrisC is offline
post #15 of 15 (permalink) Old 01-07-2008, 07:54 PM
BlueMule's Avatar
My Photos: (12)
Powerstrokes were not fully OBDII compliant until the 99's
Rodney#33
BlueMule is offline
