Re: codes and shifting problems
mine just did the same thing today. does the speedometer work?had the VSS and CPS codes also. the VSS going bad or not working will make the trans get hot and TC slip. mine was just a blown fuse(LUCKY me). does your dome light work?i know your thinking whats that got to do with it. the fuse that was blown was not anything to do with the speedo or PCM but was #9(i think)which is the dome light fuse. hope you get out easy. Rob
2008 GMC 2500 HD Duramax Crew Cab 4x4
SOLD
1997 F-250HD , 4x4, auto 3.55 LS gears
TYMAR intake,
3" downpipe,4"exhaust
285/75 BUCKSHOT MUDDERS
B&M turnover ball
DMI quickcushion II rear bumper
DIY coolant filter
DIY bypass oil filter
DIY trans filter
