Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 01-21-2008, 12:01 PM   #1 (permalink)
Cold Starting Issues/ Need help Diagnosing
Came out this moring and found out I had two problems. . .
#1 Engine block heater was plugged in, but engine was cold as it was outside 5* or so.
I cycled the glow plugs a couple of times and
#2 Engine fired but really really rough idle and I threw a CEL. Sounded like I was only on 4 or 7 cylinders.
I have been getting a LOT of smoke on the 30* mornings typical here in Ohio, but how do I fix the two problems. Is there an easy relay or fuse that could cure the block heater issue, and are the two problems related. Engine too cold and maybe only one side of glowplugs working, because after a couple of minutes of idleing, the CEL went away and the truck ran fine
thanks for your help, any input appreciated, this site always saves a ton of time in troubleshooting!
1996 PSD, XL, 2wd, SRW
331,000 miles. Amsoil Synthetic, and Cat extended life coolant. Diesel Site 203* T-stat. 4 inch straight piped exhaust. Tymar intake. Leather Captains Seats. 120 gal. Heated Veggie tank in rear. Shimmed FPR. TS 6 Pos. Chip (stock, hi-idle, 50,75,100,140). DIY Stage 1 150cc injectors. Valaire Con O Clutch. Stainless 10" drop 15K hercules rear bumper. 3 gauge pillar pod: autometer digital boost, pyro, voltmeter. BFG AT's 285/75/16
Pulling a 31' 1985 Airstream Excella
1986 Hunter 23
huberjoshua is offline
Old 01-21-2008, 12:21 PM   #2 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
only real problem with block heater could be cord bad or not plugged into good power from house
Your glow plug relay should be replaced if old and you could have a bad glow plug and theh should be checked with ohm meter
Jim Sult / Excavator (we dig it)
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
1997 F350 XL DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 175,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Excavator is offline
Old 01-21-2008, 12:30 PM   #3 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
Glow Plug Replacement and Relay Swap
here is goog place to look at
Truck Pics
Fan clutch wrench
Old 01-21-2008, 01:46 PM   #4 (permalink)
If I still have a draw on the engine and the volts go down and lights dim for a few minutes after starting, should my relay be good? Any way to test? I have noticed (i think after the TS chip install that the wait to start light doesn't stay on as long)
What is the Stancor Relay about?
1986 Hunter 23
Old 01-21-2008, 01:52 PM   #5 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
Yes with some chips light does not stay on same length as no chip.
Your volts may be dropping as you say but relay might not be sending enough accross the 2 large post to get 100% volts needed.
Truck Pics
Fan clutch wrench
Old 01-21-2008, 01:55 PM   #6 (permalink)
okay I'll just replace it especially if its under 20 bux at autozone and go from there
Thanks for your Help!
1986 Hunter 23
Old 01-21-2008, 01:58 PM   #7 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
To test relay you have to be quick
use volt meter on 1 large post with single wire and check volts
then check volts on second large post before glow plug relay is turned off.
volts should be just about the same accross 2 post
Also the light on dast is independant from relay
Truck Pics
Fan clutch wrench
Old 01-21-2008, 06:04 PM   #8 (permalink)
Replaced the block heater plug and put it into a trailer plug housing mounted on the front bumper. The old plug was pretty corroded, and the wire back into the pigtail was corroded as well from all the salt from the old plug hanging in front of the truck. Block heater works now and I should be able to get the rest of my starting issues figured out.
Is there a good write up on installing a stancor relay, that seems the way to go
1986 Hunter 23
Old 01-21-2008, 06:15 PM   #9 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
This is for newer 2002 powerstroke but it is close to same
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Truck Pics
Fan clutch wrench
Similar Threads
Starting Issues ohiopsdx17 Power Strokes 1994-1997 General 6 01-08-2008 12:44 PM
Help... Starting issues/ Charging issues fautnsmllit Power Strokes 1994-1997 General 6 07-19-2007 12:24 AM
starting issues TJTOM General Questions 3 11-17-2006 05:40 PM
Starting issues... bogeyman 6.0L Power Stroke Engine and Drivetrain 4 11-10-2006 02:04 PM
cold starting issues-electrical HELP graytrain 7.3L IDI Diesels (Not Power Strokes) 6 09-27-2006 11:01 AM
