Common oil leak on passenger front side of engine? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-03-2010, 06:06 PM Thread Starter
I can't quite spot where the oil is coming from. Its a slow leak but appears to be coming basically from the passenger side of the motor, towards the front top. Its dry below the valve cover but the oil seems to come down then back and is drenching the frame and oil pan down on that side.
I vaguely recall an o-ring in the head or something of that sort being a common culprit in that area. Anyone got any ideas? Thanks!
edit: may have found the info.
Oil Rail End Plugs (large plugs at each end of heads; incl. O-rings, use LOCTITE #11747 to seal threads)
(Ford) Same number as International
(International) 1827535C94
Oil Leak on Right-Front of Engine
I'll take a closer look tonight but feel free to add any ideas you have in the mean time.
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 1.0 exhaust housing, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip (five of them work
Tankota is offline
post #2 of 6 (permalink) Old 09-03-2010, 10:29 PM
Patrick Feeley's Avatar
My Photos: (19)
The oil rail end plug would be my first check. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 6 (permalink) Old 09-03-2010, 11:56 PM Thread Starter
Took a while to find it but I do believe you are correct. Looks like the alternator and belt tensioner/idler have to be removed to get to it. Is that it?
Tankota is offline
post #4 of 6 (permalink) Old 10-10-2010, 07:28 PM Thread Starter
That definitely was the leak and didn't take too long to pull the alternator and the idler assembly to replace the oil rail plug.
however, now the truck idles like its running on 6-7 cylinders and takes alot of cranking to start.
Is this just air in the oil rail and will go away after some extended driving?
Tankota is offline
post #5 of 6 (permalink) Old 10-10-2010, 09:12 PM
My Photos: (19)
Should just be air in the rails after opening it up. It'll work itself out. Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #6 of 6 (permalink) Old 10-10-2010, 10:43 PM Thread Starter
Thanks!
Tankota is offline
