I'll try not to make this too long. My son has a 95PS. We bought it from a friend who bought it used with about 9K on it. He had engine and tranny problems, so at some point the local Ford dealer installed a new 97 engine and tranny. The new engine has less than 80K on it. Occasionally slowing down for a stop sign the truck dies. It fires right back up. My son is in the SEABEES stationed in Calif. so doesn't have a lot of money to throw at the problem. On the older powerstrokes if the CPS acts up will it set a code? If it was a newer one like mine that would be the 1st thing I'd look at. Any thoughts? Thanks in advance
01F350 CC 4WD 6SPD Arrow Canopy, 305/70/16's on 16"X8"wheels, HX mod, IAH plug, AFE Stage I w/pro guard 7 filter and overcoat. Evo tuner, WW, 4"exhaust,zoodad, Amsoil, Isspro gauges, GOS headlight harness,coolant filter
Endowment Member NRA
Mine was doing the same thing when I bought it, 3 years and 30k miles ago. I replaced the CPS and never had another problem until last week. Now my truck is doing it again. I have a Superchips tuner that I can read codes with and the truck is setting a code for the CPS (but no CEL). I couldn't read the codes the first time I had the problem, so I can't tell you if it was seeting a code the first time or not.
I'd say it is most likely the CPS.
If you want to save money buy the new one from an International dealer and not a Ford dealer. It should be about half the price (~$100 instead of ~$200) Also, with the engine swap I would recommend that you get the engine serial number and take it with you there are different CPS's depending on what SN range your engine falls into.
Dan
1997 F250 XLT 4X4 CC E4OD.
Mostly Stock, Shimmed Regulator, EBPV Exhaust Brake, TC Lock Switch, A/C mod., 165K miles, GPR monitor LED, Energy Suspension bushings, Dual Pulley Tensioner, DIY Baldwin by-pass filter, Baldwin Air Filter, Coolant Filter, Down Pipe, Firestone Front Airbags.
DGLENN. Yes I would go to International. I've not spent much time in this forum. Would I be correct in thinking that Ford did some engine changes between the 95 and 96 model years?
I'm no expert on the subject, but I'll just re-post something I have filed away from a long ago post I read.
§ The CMP sensor has also been changed to incorporate gold plated pins. There has also been changes in length and circuitry since 1994. To identify each CMP sensor there is a part number suffix located on the top of the sensor near the sensor wiring connector. The CMP with a part number suffix of C96 is 1.152" ± 0.006" in length and has tin pins, this sensor was used in engines with serial number between 000501 and 033780. A C96 sensor should not be installed as a replacement sensor. The sensor with a C97 suffix is tin plated and 1.152" ± 0.006" in length. This sensor has improved circuitry over the C96 sensor. The C98 sensor is identical to the C97 except for the length, it is 1.142" ± 0.004" in length.
§ Due to the change in wiring harnesses three new sensors were made with gold pins. The C91 sensor is 1.152" ± 0.006" in length, which was used in engine serial numbers 375549 through 408253, and the C92 is 1.142" ± 0.004" in length, which was used in engine serial numbers 408253 through 623916. A sensor with a part number suffix of C93 has gold pins and a length of 1.142" ± 0.004", this sensor has improved circuitry over the C91 and C92 sensors. The C93 sensor is being used as of engine serial number 623916.
§ The camshaft position sensor circuitry has been updated to be less sensitive of clearance to the trigger wheel.
§ The part number suffix for the gold plated sensor is C93, and C99 for the tin plated sensor.
Hope that helps.
Dan
I just had the same problem with my '95 model. Ordered a new CPS (OEM) from powerstrokeshop.com (a sponsor of this website) for $86.45 + shipping. Now it's running perfectly again.
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
